Pre Treated Wood Or XPS Or FoamSeal - Insulation - DIY Chatroom Home Improvement Forum
Old 01-25-2012, 06:46 AM   #1
Pre Treated Wood or XPS or FoamSeal
Hello all,
I am about 95% complete with insulating my concrete walls with XPS. I was able to glue them but I spent alot of time smoothing out the walls with my Fatmax chisel. Anyway, my next step is framing! My question now is what is the best method for protecting the base plate from rotting? Do I use XPS, or the Owens Corning Foam Seal, or pre treated wood? Ideally I would want the most cost conscious choice however if one is really better than the other I would probably go that route.
rickcet is offline   Reply With Quote
Old 01-25-2012, 08:51 AM   #2
I would use a treated bottom plate. I'm not sure what types of treatment are available in Chicago, but MCA treated lumber is much drier than ACQ treated lumber. Should be your least expensive option, also.
AgBuilder is offline   Reply With Quote
Old 01-25-2012, 09:34 AM   #3
Thanks for the quick response. Since I will be cutting this wood inside, isn't the sawdust unhealthy to breathe in and do you also have to coat the cut ends of the PT wood? -thx
Old 01-25-2012, 09:37 AM   #4
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 690
Treated lumber is fine, you don't have to treat the ends. The chemicals that treat the lumber are forced into the wood, they are not just a coating on the surface.
hyunelan2 is offline   Reply With Quote
Old 01-25-2012, 09:41 AM   #5
PT Wood or XPS or FoamSeal as a Base Plate?
Old 01-25-2012, 10:59 AM   #6
AGWhitehouse's Avatar
Step #1: Place Sill Seal (Foam roll good available at most box stores)
http://building.dow.com/na/en/applic.../sillplate.jpg
Step #2: Place pressure treated wood sill over sill seal and attach to floor
http://img.diynetwork.com/DIY/2004/07/27/dbhb105_4fa_lead.jpg
Step #3: Erect stud wall. You can use only a single p.t. wood sill or you can add an addition sill plate for a double plate assembly. The upper plate would not have to be pressure treated.
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 01-25-2012, 11:00 AM   #7
This is a double post...it's also in the insulation forum...
Painting Pressure Treated Wood stephen44 Painting 14 05-14-2016 08:22 AM
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
ICF vs. Wood Framed JackOfAllTrades Building & Construction 31 11-01-2011 03:14 PM
Pressure treated wood does or does not need to be painted???? stanlam Building & Construction 11 03-27-2011 03:04 PM
HELP! I did not use treated wood. Any solutions? Smith305 Remodeling 8 04-03-2010 04:48 PM
