Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 09-13-2011, 11:36 AM   #1
Question
Pour Foam insulation between double brick
Hello,
I am living in an older home, build in 1927. There is no insulation in the walls and some of the walls are lathe and plaster. I just moved in last fall and I insulated the attic but I still found the house cold in the winter and hot in the summer. Well, upstairs was the worst, the bottom floor wasn't too bad. I have a friend who has a similar aged home and had spray foam injected into the walls between the brick and he noticed a big difference (however, he did a few other improvements at the same time). I think the product is: ICYNENE LD-CP-50 Pour Foam.
Also, I had an energy audit guy say that it is a good option as well. However, I can't seem to find much info on the benefits of this except from the makers of the product and the people who install it. Has anyone else tried this?
Thanks.
devin is offline   Reply With Quote
Old 09-13-2011, 12:30 PM   #2
Tileguy
Bud Cline's Avatar
That "air-space" is there for a reason and is an integral component of the masonry structure. It (the space) creates a thermal barrier and also allows any moisture that gets through the mortar to dry properly. To inject those spaces with foam would only be the beginning of the end for the exterior structure. The foam will hold migrating moisture and if you are in a winter-freeze area expansion from freezing will eventually demolish the masonry wall for you.
For some one to claim they have filled that 1" space and noticed a difference is just plain baloney. They are just trying to justify a bad decision.
As you said...the only people recommending the procedure are the people selling the product to perform the procedure. I would leave it alone.
Old 09-13-2011, 01:31 PM   #3
Thanks for your quick reply. I am glad I posted here before going ahead with this.
However, I was actually mistaken on what my friend did. He put the insulation between the plaster and the brick. So they drill through the wall but not the brick and inject the foam in there. Does this sound like a good option? Has anyone else done this?
Thanks so much.
Old 09-13-2011, 01:39 PM   #4
Exterior Construction
Windows on Wash's Avatar
+1
You are messing with what can be a devastating change in the building structure. There was a very good article in Green building Adviser.
http://www.greenbuildingadvisor.com/...rick-buildings
Seal up the top plates of the wall (most like balloon framed) and be done with it.
foam insulation and venting lizhsharpe Insulation 5 04-06-2011 01:01 PM
Adding batt insulation to foam for increased R value Mike Mike Building & Construction 3 02-22-2011 01:55 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
Rigid foam sheathing on top of foam insulation? benjamincall HVAC 12 02-04-2009 01:41 AM
Exterior Foam Insulation Help??? teachtech Building & Construction 3 11-29-2008 11:19 AM
