Poor Open Cell Sprayfoam Job, Can I.. - Insulation - DIY Chatroom Home Improvement Forum
Old 01-22-2012, 12:31 PM   #1
Poor Open cell sprayfoam job, can I..
I built a new ICF (Insulated Concrete foam) Ranch home with an elaborate roofline with hips etc. The original Sprayfoam contractor did not apply the amount of foam that was dictated in the contract. We went to court and got some money but nearly enough. We have some of the worst Ice dams in the neighborhood. The attic is Spray foamed on the roofline but nearly enough, some areas only have 1-2" of Open 0.5 foam. The walls obviously dont reguire additional foam.
Could I apply Atticat insulation to the attic floor? Will this cause any additional problems down the line? It is an unused attic and to be honest is cavenous due to the style of the roof. Can I cover the numerous can lights that are installed? These are IC recessed lights but NOT air tight? I also have AC vents in the ceiling (6") in case we ever installed air conditioning. How should these best best economically covered below the insulation?
Lastly how should the sides of the walls Skylights be insulated and also the rooms that 10-11' high? Should the area that extends up from the floor have conventional insulation cut to fit these voids? Thank you
jmbeam is offline   Reply With Quote
Old 01-22-2012, 03:17 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 864
Yes and it should not cause any issues.
Yes and you should cover the lights. Make your own airtight boxes to go around them or seal them other some other way. Easiest material is usually drywall board and it is fireproof too.
Cover the vents with the same boxes and mark them (just like the lights) with flags so they can be easily found in the future.
You can back the skylight shafts any number of ways. Rigid foam, batt insulation with a proper air barrier over it, spider insulation (i.e. spray on fiberglass), etc, etc. Make sure whatever way you do it that it is code compliant and this same methodology can extend to what should be insulated kneewalls as well.
see above....
Old 01-23-2012, 07:12 PM   #3
Registered User
Rewards Points: 4,912
1. Where are you located?
2. Is there attic ventilation?
3. Is there plastic on the ceiling below?
Read "Code citations": http://resourcecenter.pnl.gov/cocoon...r/article/1520
Gary
Old 02-03-2012, 09:44 AM   #4
1. Where are you located? Upstate New York
2. Is there attic ventilation? NO
3. Is there plastic on the ceiling below? NO
Old 02-03-2012, 10:28 AM   #5
Rewards Points: 864
Air seal all the cans, top plates, and other penetrations in the air barrier.
At that point, fix the skylight shafts and blow in and R-50 to the attic.
Once that is done, you may want to consider converting to vented attic assembly given the fact that the hot roof (spray foamed roof) was done completely inadequately and is not functioning as one should.
Issue with a definite purpose contactor and photo cell. bigmacfann Electrical 43 09-16-2011 04:56 PM
open cell or closed cell in attic?? JulesB Building & Construction 4 02-13-2011 10:09 AM
closed cell insulation vs. fiberglass bats ben5048 Roofing/Siding 6 01-15-2011 09:47 PM
Pern value of 8 inches of open cell foam millertimeny Building & Construction 0 03-23-2010 12:28 PM
closed cell vs open cell foam insulation amonalisa Building & Construction 1 11-06-2008 10:39 PM
