Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 08-21-2011, 11:19 PM   #1
Polystrene foam
I recently received a load of polystyrene foam fir free and I was wanting to install it on the ceiling in my attic to give some type of insulation bc there is nothing currently there. Is this a good idea? Do I need some type of vapor barrier ? I'm kind of lost on this one.
Jhd128 is offline   Reply With Quote
Old 08-25-2011, 09:36 AM   #2
jburd964's Avatar
Polystrene foam
I suppose these are the sheet of foam that your talking about. If so this sheets aren't that great of a insulator. Depending on your location as to the amount of saving it will get you. Seeing as it was free it's better then nothing. If it were me and I was going through the effort, which will be a lot to install sheet insulation in a attic, I would spend the amount that it would cost and blow in some Cellulose insulation. It's not my favorite insulator but cheap and easy of use in a attic.
jburd964 is offline   Reply With Quote
Old 08-27-2011, 02:30 PM   #3
Moderator
Polystrene foam
Where are you located?
What thickness and type/color foam board?
Is any HVAC in attic?
And, welcome to the forum!
Gary
Clothes taking longer to dry?
Old 08-27-2011, 03:14 PM   #4
Polystrene foam
Thanks! I live in Dallas and it's Dow plazamate foam board. There is hvac in the attic and I know it's a little bit of work but u figured anything would be better than nothing for now.
Old 08-28-2011, 11:32 PM   #5
Moderator
Polystrene foam
Here is a good one to get you started: http://www.buildingscience.com/docum...ditioned-space
Click on others at the bottom of page.
Another one; http://www.buildingscience.com/docum...on?full_view=1
And finally: http://www.joelstiburek.com/topten/south.htm
Gary
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
Replace Flange in basement with Foam? mattoxda Plumbing 1 10-10-2010 05:05 PM
Hybrid wall insulation consisting of 2" rigid foam + 2x4 fiberglass batts? TitaniumVT Building & Construction 15 09-14-2010 03:50 AM
Foam Board on exterior of above grade house Sheldon General Discussion 6 12-08-2009 05:05 PM
closed cell vs open cell foam insulation amonalisa Building & Construction 1 11-06-2008 10:39 PM
