-   Insulation (http://www.diychatroom.com/f103/)
-   -   Polystrene foam (http://www.diychatroom.com/f103/polystrene-foam-114842/)
Jhd128 08-21-2011 11:19 PM
Polystrene foam
I recently received a load of polystyrene foam fir free and I was wanting to install it on the ceiling in my attic to give some type of insulation bc there is nothing currently there. Is this a good idea? Do I need some type of vapor barrier ? I'm kind of lost on this one.
jburd964 08-25-2011 09:36 AM
I suppose these are the sheet of foam that your talking about. If so this sheets aren't that great of a insulator. Depending on your location as to the amount of saving it will get you. Seeing as it was free it's better then nothing. If it were me and I was going through the effort, which will be a lot to install sheet insulation in a attic, I would spend the amount that it would cost and blow in some Cellulose insulation. It's not my favorite insulator but cheap and easy of use in a attic.
Gary in WA 08-27-2011 02:30 PM
Where are you located?
What thickness and type/color foam board?
Is any HVAC in attic?
And, welcome to the forum!
Gary
Jhd128 08-27-2011 03:14 PM
Thanks! I live in Dallas and it's Dow plazamate foam board. There is hvac in the attic and I know it's a little bit of work but u figured anything would be better than nothing for now.
Gary in WA 08-28-2011 11:32 PM
Here is a good one to get you started: http://www.buildingscience.com/docum...ditioned-space
Click on others at the bottom of page.
Another one; http://www.buildingscience.com/docum...on?full_view=1
And finally: http://www.joelstiburek.com/topten/south.htm
Gary
