Pole Building Insulation Question - Insulation - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-14-2012, 10:09 AM   #16
Greg
I purchased manufactured beams made out of wood from a local building supply store. They were cheaper than just about every thing else and are rated for a 2nd floor. All I plan to do is put boxes up there etc.
these give me plenty to attach drywall with. I can also insulate normally.
scuts is offline   Reply With Quote
Old 03-16-2012, 01:01 PM   #17
Looks like your roof is taller than mine. I'm not doing a ceiling like yours with beams. My roof trusses are about 4 - 5 feet apart. Any suggestions on how to put a ceiling in there? I'm trying to upload a pic for reference. I would like to just put up ceiling tiles. Can you just roll insulation on top of the ceiling tiles?
bkanneg is offline   Reply With Quote
Old 03-16-2012, 01:06 PM   #18
Greg
I would let the pros chime in. If it were me with my limited knowledge I would go in with 2x6's between the trusses on 16-24" centers. Then use that for your sheetrock / ceiling track to screw to and roll the insulation on top of it. There should not be enough weight in the insulation to make the tiles have an issue. Then again you could blow it in to your liking.
Old 03-16-2012, 01:36 PM   #19
Just throwing this out there, Dose steel breathe?
Writerís information is for discussion purpose only and should be confirmed by an independent source.
I am not an expert and donít claim to be, these are just my views and opinions.
Hardway is offline   Reply With Quote
Old 03-16-2012, 09:18 PM   #20
Any danger of the 2x6s causing the trusses to lose structural integrity? Could they hold all the 2x6s and drywall and insulation without putting too much stress on the tresses. Don't want the roof to fall in on my man cave!
Any structural engineers out there have any thoughts?
new wall insulation question s002wjh Building & Construction 9 01-05-2012 01:57 PM
yet one more insulation question Mike in Arkansas General DIY Discussions 6 11-11-2010 09:47 PM
Old Home - Basement addition insulation vapor barrier question 1870 Building & Construction 0 10-14-2010 07:36 AM
Old Building problems jake62 Building & Construction 5 08-20-2010 08:32 AM
Insulation question Branden Building & Construction 1 08-03-2010 01:02 PM
