Plugs Used For Blown Walls - Insulation - DIY Chatroom Home Improvement Forum
Old 05-16-2011, 09:52 PM   #1
Plugs used for blown walls
Hi,
Just had exterior walls blown. They pounded in wood plugs and I noticed that they used some styrofoam plugs also? Is this the way it should have been done?
Thanks,
Jim
bostonbees is offline   Reply With Quote
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 09:50 PM
Delta-FL on floor and XPS on walls. Should I install the flooring or the walls first? yotaman Remodeling 11 04-19-2011 10:20 AM
No Floating walls where there should be! DIY Master Building & Construction 1 02-23-2011 06:06 AM
Finishing Basement Walls, Inside Perimeter Drains, and Moisture, Oh My BSponz1 Building & Construction 1 02-08-2011 02:20 PM
load bearing walls worriedowner Building & Construction 3 02-02-2011 05:12 PM
