Permanent Caulk - Insulation - DIY Chatroom Home Improvement Forum
Old 02-08-2012, 02:22 PM   #1
Rewards Points: 131
permanent caulk
for filling crack between concrete foundation and Sill plates(below the rim joist) do i use polyurethane caulk or silicone caulk? is polyurethane can only use on concrete/mortar not ideal for wood/concrete crack filling?
s002wjh is offline   Reply With Quote
Old 02-08-2012, 05:25 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,742
For the interior and being used for air seal?
If so, tuck a foam straw in the larger gaps and seal them up with some of that or use backer rod.
After that, any good sealant will work. Try to get the bulk dust off the top of the concrete so it is bonding to something with some tooth.
Recaulking at previously silicone-caulked shower door frame hffeagan Kitchen & Bath Remodeling 36 02-24-2016 02:01 PM
Bad caulk line on floor itsmehli Flooring 10 01-03-2012 09:30 AM
What type of Caulk to Use Einhorn General DIY Discussions 19 08-21-2011 02:50 PM
How to Clean Up Caulk Mess on Driveway Left By Construction Crew ToolbeltGal Building & Construction 6 09-25-2010 04:36 PM
Caulk Frustration j4ino Building & Construction 5 09-29-2008 07:03 AM
