Party Wall Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 05-22-2014, 12:01 AM   #1
I am interested in purchasing a condo, and I found out that has a staggered stud wall instead of a double stud wall. The specifications say that it has an extra 1/2" layer of drywall and R8 insulation. I am wondering if this has equivalent sound proofing to the double stud wall, or if the double stud wall is superior, although, most double stud walls only have the one layer of drywall to the party wall. Thank you for any advice.
snowman8 is offline   Reply With Quote
Old 05-22-2014, 12:07 AM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The "staggered stud" system is superior and quieter.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
snowman8 (05-22-2014)
Old 05-22-2014, 12:17 AM   #3
I have to disagree. The double stud wall, ( if built right) has seperate top and bottom plates that are not touching each other. The does not let the vibration transfer as well.
I think you may be over thinking it a little bit though. Anything is going to be better than the way they were built before.
uncommon doors is offline   Reply With Quote
The Following User Says Thank You to uncommon doors For This Useful Post:
Old 05-22-2014, 12:03 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 898
Anything in the staggered or double stud wall is going to work great.
The Following User Says Thank You to Windows on Wash For This Useful Post:
Old 05-22-2014, 06:36 PM   #5
Registered User
Rewards Points: 4,924
Find your wall here; https://docs.google.com/viewer?a=v&q...5-Nlw11eErzv_A
Gary
PS. Welcome to the forums!
The Following User Says Thank You to Gary in WA For This Useful Post:
Exterior Wall Insulation Goodball Insulation 2 09-03-2012 08:49 PM
new wall insulation question s002wjh Building & Construction 9 01-05-2012 02:57 PM
Exterior Wall Insulation require plastic barrier? BillyDIY Building & Construction 14 03-05-2009 11:19 AM
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 10:18 AM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
