Outside Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 09-08-2011, 01:00 PM   #1
outside insulation
We have enclosed our deck into a glassed in porch but the underside of the floor is exposed to the weather. What do we insulate with?
PGable is offline   Reply With Quote
Old 09-08-2011, 02:56 PM   #2
Msradell's Avatar
Rewards Points: 272
Probably the easiest way would be to have it sprayed with closed cell foam and then paint it with a UV protector (assuming light can get to it). If you use fiberglass you will just be making a great nest for critters unless you put plywood or some other material over it.
Msradell is offline   Reply With Quote
Old 09-09-2011, 08:31 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,258
Spray foam or sealed up rigid foam.
Old 09-10-2011, 08:33 PM   #4
Registered User
Rewards Points: 526
Welcome to the forum! Is the deck designed for the concentrated glass load? What R-value is called out on the deck/living space conversion plans?
Gary
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Fiberglass Insulation: How Do I Cover the Attic? chueh Building & Construction 3 11-08-2010 02:33 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
attic insulation question dderolph Building & Construction 10 11-03-2007 05:21 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
