Outdoor Patio Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 09-04-2012, 11:06 AM   #1
Outdoor Patio insulation
Our house have a 26 by 26 patio which continues to get so hot that even after the sun goes down ( Im in San Antonio ,Texas) it is better just to move the chairs outside to the pool deck than to be inside the patio...would insulation help this out?...I can feel the heat even at night emanating from the stucco
If insulation is an option...what would you recommend?...thanks
fta123 is offline   Reply With Quote
Old 09-04-2012, 11:09 AM   #2
Rewards Points: 13,300
Without being able to see the porch with a picture and know how it was built not sure how we can tell you how to fix it.
Old 09-04-2012, 11:24 AM   #3
here is the patio
Hope this helps
Old 09-04-2012, 04:31 PM   #4
AGWhitehouse's Avatar
Plant a tree or get an umbrella to get some shade there...you've got a sea of concrete that loves to absorb sun generated radiant heat...there isn't anywhere in that photo insulation would help...
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 09-04-2012, 05:24 PM   #5
Are there any ceiling fans in there?
Is there a ceiling or is it open?
Old 09-05-2012, 12:45 PM   #6
Too Short? Cut it Again!
Some flowing, outdoor, sailcloth or similar material drapery panels might give you some shade. I like a large ceiling fan or two. Plants, plants and more plants will provide some natural cooling. You do have a lot of concrete surface area if the pic still rings true?
The Following User Says Thank You to user1007 For This Useful Post:
drtbk4ever (09-05-2012)
Insulation question for vaulted home Talgonadia Insulation 3 08-22-2012 07:06 AM
?'s about foil-faced "bubble wrap" insulation badger73 Insulation 5 06-25-2012 06:09 AM
Several Insulation Quotes, Big Decisions to make knotquiteawake Insulation 2 05-04-2012 12:16 PM
Garage Insulation yamster Insulation 0 07-01-2011 02:30 PM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 09:14 PM
