Open Cell Foam Insulation Thickness - Insulation - DIY Chatroom Home Improvement Forum
Old 04-26-2014, 12:32 PM   #1
open cell foam insulation thickness
Im considering building a new home with spray foam insulation. Im putting 2 x 6s in exterior walls. Builders recommend 3 1/2 inches of foam in walls. Is that enough ? I know its expensive but is it too much to fill up the walls? How much should be sprayed in the raftors? In Texas so the heat is rough and i want a well insulated home..
mugmarine is offline   Reply With Quote
Old 04-26-2014, 12:47 PM   #2
An old Tradesmen
Rewards Points: 6,498
Gary well be along in a while to answer your question.
Old 04-27-2014, 07:53 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,834
Ha!
We need to call the "The Linksman"
I would encourage you to read up on foam and figure out if you really need it as well as get considerably strong language in the contract that allows for corrections if installed wrong.
I would prefer to see rigid foam incorporated to the design as if possible and skip the spray foam.
Code is code regardless of what you contractor says and that is what determine the insulation thickness requirements.
Pairing Rigid foam insulation with existing wall cavity Izaura Insulation 8 03-30-2013 08:56 PM
Closed Cell Foam, plastic and air space? bokaguy Building & Construction 9 03-05-2012 04:29 PM
Hybrid Spray/Rigid Foam Insulation yaemish Insulation 4 01-21-2012 12:55 AM
Closed Cell Spray Foam insulation and hiring a contractor. Spud Building & Construction 2 10-14-2009 10:03 AM
Advice on closed cell/open cell spray in insulation 794613 Building & Construction 2 10-31-2008 08:56 AM
