Old Walls With NO Insulation-now What? - Insulation - DIY Chatroom Home Improvement Forum
Old 11-11-2012, 01:58 PM   #1
Rewards Points: 48
old walls with NO insulation-now what?
Redoing a bathroom, we found there is nothing inside the framed/stucco'd walls. Had to finish that bathroom without time to do anything.
I presume the solution in the bedrooms is to open up holes and blow in insulation? And we'd need holes both towards the top and towards the bottom, as there should be firebreaks in the middle?
What should we blow in? And if we're doing just one room at a time, can we do something ourselves, or need a pro?
Head_Unit is offline   Reply With Quote
Old 11-11-2012, 02:09 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 2,116
Welcome to the land of no insulation....
Let me guess....stucco on the outside?....house was built in the 50's?.....yep....you have no insulation.
Blow in? Maybe....except that all of your walls have fire blocking....i.e., about half way up is a block of wood between the studs....you would have to knock holes all over the wall.
You will just have to call around and get input from contractors.
My architect is also a contractor....he is in the South bay.....let me know if you want his #....the guy is good.
ddawg16 is online now   Reply With Quote
Old 11-11-2012, 04:33 PM   #3
Rewards Points: 6,652
If the walls are Drywall, you can cut a strip at the top to allow the crew to blow in. If GypRock (Gypsum board with Plaster over the top), they can use a hole saw to cut the holes also. Either way will work. As for fireblocking, they can take a camera like this http://www.amazon.com/dp/B002JWUKOS/...SIN=B002JWUKOS
Insulation for walls in South Florida Amberlily Insulation 3 08-09-2012 02:52 PM
Basement insulation - 2 walls chigundo Remodeling 1 04-02-2012 09:11 PM
Basement Exterior Above Grade Insulation purpasadu Building & Construction 6 02-28-2012 04:42 PM
Fiberglass Insulation: How Do I Cover the Attic? chueh Building & Construction 3 11-08-2010 02:33 PM
Rigid Insulation on the interior walls during remodel KHM Building & Construction 2 04-29-2009 09:08 PM
