-   Insulation (http://www.diychatroom.com/f103/)
-   -   old walls with NO insulation-now what? (http://www.diychatroom.com/f103/old-walls-no-insulation-now-what-162961/)
Head_Unit 11-11-2012 01:58 PM
Redoing a bathroom, we found there is nothing inside the framed/stucco'd walls. Had to finish that bathroom without time to do anything.
I presume the solution in the bedrooms is to open up holes and blow in insulation? And we'd need holes both towards the top and towards the bottom, as there should be firebreaks in the middle?
What should we blow in? And if we're doing just one room at a time, can we do something ourselves, or need a pro?
ddawg16 11-11-2012 02:09 PM
Welcome to the land of no insulation....
Let me guess....stucco on the outside?....house was built in the 50's?.....yep....you have no insulation.
Blow in? Maybe....except that all of your walls have fire blocking....i.e., about half way up is a block of wood between the studs....you would have to knock holes all over the wall.
You will just have to call around and get input from contractors.
My architect is also a contractor....he is in the South bay.....let me know if you want his #....the guy is good.
gregzoll 11-11-2012 04:33 PM
If the walls are Drywall, you can cut a strip at the top to allow the crew to blow in. If GypRock (Gypsum board with Plaster over the top), they can use a hole saw to cut the holes also. Either way will work. As for fireblocking, they can take a camera like this http://www.amazon.com/dp/B002JWUKOS/...SIN=B002JWUKOS
