Old Mailbox Big Hole On The Wall - Any Idea For Fixing? - Insulation - DIY Chatroom Home Improvement Forum
Old 09-24-2011, 03:19 AM   #1
Rewards Points: 200
Question
Old mailbox big hole on the wall - any idea for fixing?
Dear all, we have an old house that we no longer use the outside mailbox, which create a huge hole on the wall. See these two photos (out from the outside, the other from the inside)..
http://postimage.org/image/1eox4nxus/ (outdoor view)
http://postimage.org/image/1epfbkrac/ (indoor view)
Currently, as you can see, we are using some tapes to tape it (from inside of the house) to better weatherproof it. However, this is not just ugly, but most of the time it doesn't work well... Any ideas how this should be fixed? Many thanks!
ohman is offline   Reply With Quote
Old 09-24-2011, 08:21 AM   #2
Rewards Points: 1,452
Line the inside cover with cardboard. Spray in Great Stuff from the outside. After it dries, carve the outside surface to be smooth and paint it.
By the way, if you stuffed in fiber glass insulation you could still get away with painting the exposed fiber glass on the outside (to hide the pink color).
Old 09-24-2011, 09:03 AM   #3
looks like a very difficult job to match exterior texture.
maybe cut a piece of plexi glass to fit the hole/add your address and insert.
stuff insulation in the wall to stop draft.
Marbledust is offline   Reply With Quote
Old 09-25-2011, 01:55 AM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,994
Any insulation you can stuff in the wall does not stop the draft.
I would seal it from the inside (install rigid board, probably a 2 piece affair) and seal it with foam or caulk.
I think the exterior detail is charming.
Old 09-25-2011, 01:35 PM   #5
Charming?
silly boy
Old 09-26-2011, 10:49 AM   #6
DIY staff
Rewards Points: 7,174
Lighten up there Marbledust---No need to turn a helpful suggestion into a personal jab.
Charming is in the eye of the beholder---Mike-----
Old 09-26-2011, 01:01 PM   #7
Ole Wood Worker
BigJim's Avatar
Rewards Points: 202
If it were mine I would exaggerate it, if the outside plate is brass I would clean it up and seal the inside cavity like WOW said. If it isn't brass I would look for one or maybe a different style or even paint the plate black. That is what what makes the world go around, different tastes.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 08-01-2012, 04:48 AM   #8
Please tell me, did you set up this mailbox by yourself or you have taken some help from the mailbox company?? There are different types of mailboxes that you can install outside of your house. If you try this then you will never face this kind of problem.
tonnygarden is offline   Reply With Quote
Old 08-01-2012, 07:07 AM   #9
the Musigician
DangerMouse's Avatar
Looks to me like the "flip-up" door is missing on the outside. If you do not want to patch it, you could look for a replacement? The newer ones will have weather-stripping on the door.
DM
Old 08-01-2012, 12:11 PM   #10
Ole Wood Worker
BigJim's Avatar
Rewards Points: 202
I wonder what the OP did, this thread is almost a year old.
Jim
Sealing the Hole in Exterior Wall Lollymagoo Carpentry 4 03-07-2011 05:26 PM
Building a half wall: 2 questions kbizzle Carpentry 7 02-19-2011 09:22 AM
Cutting hole in basement wall bladesj Remodeling 4 06-14-2009 06:41 PM
Hole in new construction basement wall AprilQ Building & Construction 5 07-08-2008 07:14 PM
Going to build a retaining wall. Want to run my idea by you guys and gals keyser soze Landscaping & Lawn Care 5 03-17-2008 06:33 PM
