OLD House, Outside Walls, Plywood Sheathing Instead Of Insulation OK?? - Insulation - DIY Chatroom Home Improvement Forum
Old 01-20-2014, 02:16 AM   #1
OLD house, outside walls, plywood sheathing instead of insulation OK??
Greetings everyone, I am going through my 200+ year old farmhouse and gutting each room, one by one, and replacing with drywall. I wish I could save the original plaster, but it is too far gone and cannot be salvaged. I want to preserve the original woodwork/molding and I don't want to touch it/alter it in any way. This is a priority. It must stay! and hence, my dilemma...
With the woodwork a priority, insulating these exterior walls is not really an option. I only have about an inch of wall thickness to play with, and I am absolutely, positively, no way no how on God's green earth messing with the woodwork! (Are we clear?http://www.diychatroom.com/images/smilies/laughing.gif ) So as long as the woodwork stays, life is good and I am happy.
So here's my plan: spray expanding foam in between the gaps of the vertical planks (see photo), and then attach plywood sheathing over the planks. So now our walls are all plywood. I'll need to leave a gap between the pieces of plywood for expansion so they don't buckle. I want to caulk these gaps/joints, including, of course, caulking around the windows and woodwork. Any/All seams will be caulked!! My goal here if u haven't guessed is to make the wall as air tight as I can. Next will be drywall, primer, wallpaper. (There will be no wires, or anything, penetrating the exterior walls, in order to minimize air flow to/from outside. Outlets will be the track mounted type.)
Does this seem reasonable? Has anyone done something similar? I'm a little hesitant to use the expanding foam in between the vertical planks bc the house needs to breath-- moisture needs to get out. I obviously don't want to trap moisture anywhere, but I don't want to invite the cold air inside either. I appreciate any feedback people can give! Thanks!!! http://www.diychatroom.com/images/smilies/thumbup.gif
tcook555 is offline   Reply With Quote
Old 01-20-2014, 09:10 AM   #2
Rewards Points: 13,732
Plywood only has an R value of about .875 per inch.
Your area calls for R 19 in the walls.
You do the math.
Just an all round very pore plan to try and do it your way.
Solid wood will just tend to transfer the hot or cold outside without any thermal bridging.
Modern electrical codes also call for outlets along those walls.
http://www.renovation-headquarters.c...m#.Ut0657Qo7IU
Surface mounted outlets would be one ugly way to do it.
I understand that's not what you wanted to hear but your way is not legal or going to work.
That trim can be removed and reused once the walls built out.
Old 01-20-2014, 01:44 PM   #3
I appreciate the information from Joe, I really do, and he is correct, that is not what I wanted to hear. But I should've provided some more background on my project. I totally hear what joecaption is saying though, I understand it, I understand the science and codes, etc.. and he is certainly correct. It is sound advice, and definitely the rule of thumb for construction in our modern world where we have the latest scientific data, tools, and building materials right at our fingertips to maximize our comfort and efficiency.
BUT... (yupp u knew it was coming!)
This project of mine isn't very much concerned with comfort and efficiency. I know, I lost a lot of you by saying that, and some of you are shaking your heads in bewilderment. "What in the world is he talking about!!??" That's ok! You see, this is more art than it is science. This restoration project is all about preserving a piece of American history, a valuable part of our past, which all to often is simply neglected/torn down/destroyed, etc.., gone forever. Yes, I am a local history buff, but I also have a background in building construction. Not everyone has an eye or appreciation for old architecture and craftsmanship, but I do and that's a huge part of this. I digress..
So the goal here is to RESTORE (not renovate/upgrade) this house back to the original house, as much as possible, and to preserve as much of the original house as possible (including materials and construction techniques). This means not touching the woodwork, not changing the dimensions of any space, not installing energy efficient windows, vinyl siding, etc..! You see, it's that special character and charm that you get from an old New England farmhouse, that is so important here. You just can't get that anywhere else, and that's really what this is all about. And I'm a stubborn man and I don't care what anyone says-- the moment you start messing with the original woodwork by tearing it down, cutting it down to size, building out walls, etc.. you start messing with the character, and then it's just not the same. You lose something special when you do that stuff, and that's just not something I'm willing to even consider. Sure it might not be efficient, it might not be toasty warm, it will probably get cold and drafty in the wintertime. But that's to be expected from a 200+ year old New England farmhouse, right?. And if that's the way our forefathers lived, and if that's what it takes to preserve their work and craftsmanship, and elegant, beautiful woodwork, then that's what I'm going to do. It's THAT important to me.
I know not many people will agree with me on this issue, or understand what I mean by the charm and character of an old farmhouse. And that's OK! But I also know there are a few people out there who know EXACTLY what I am talking about and share this same passion that I do for history and old architecture. You are the ones I want to hear from!
So... by now, if there's anyone still reading... I basically am looking to put plywood over the vertical planks, seal the gaps with caulk, then put drywall over the plywood, prime, and wallpaper. The wall will then be flush with the molding. And will be fairly airtight. Other than the lack of R-value by doing it like this, does anyone see any problems with doing it this way? My main concern is moisture not having an easy way out and causing problems inside the wall cavity.
I appreciate any feedback/info from anyone!!
And SORRY for the LONG POST!!
Old 01-20-2014, 05:18 PM   #4
Bump to move up
Old 01-20-2014, 05:56 PM   #5
Registered User
Rewards Points: 5,516
Just add 1/2" of XPS (2perms) then the drywall (30perms), don't seal the gaps in sheathing boards. Air seal both the fb and the drywall, offset joints (incl. fb on sheathing board), caulk/canned foam perimeter of fb; http://www.buildingscience.com/docum...wall-approach/
Plywood (0.70perms) What type of siding?
Gary
Old 01-20-2014, 09:08 PM   #6
Rewards Points: 236
XPS, thats what i was going to say.
and i can dig the preserving the house old character thing
Fix'n it is offline   Reply With Quote
Old 01-21-2014, 06:18 AM   #7
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,718
I can appreciate that preservation of the look as well.
Zipping up that interior wall tight and providing some thermal break will make a huge difference.
Whole house insulation advice... Huggins90 Insulation 7 02-02-2013 09:46 PM
Zone 6 - Wall Insulation: building out 2x4 walls DoItMyselfToo Building & Construction 15 05-06-2011 08:36 AM
Installing plywood or chipboard over 1X6 planking on a 52 year old house' roof. JBfromSD Roofing/Siding 2 09-20-2010 10:09 PM
House without exterior sheathing? magnusrw Building & Construction 2 06-06-2010 02:13 PM
Insulation of interior walls around fire place ODD Calmeier Building & Construction 5 01-31-2010 05:59 PM
