Old Home Insulation Upgrade During Remodel? - Insulation - DIY Chatroom Home Improvement Forum
Old 07-04-2013, 10:21 AM   #1
Old home insulation upgrade during remodel?
I just purchased an old home (~1910) that was converted to a duplex in the 70's that needed some major cosmetic work. When I purchased it the previous owner performed very little in maintenance and upgrades of the property, he apparently did not see the potential for return on investment. However, I am not a slum lord and removed all of the 70's style wall paneling and intend to replace it with drywall. After removing the panels I discovered that the exterior wall in the living room was fitted with fiberglass (that appears fairly old) while the bedrooms had the old slats and plaster. Being from Northern Minnesota where temperatures in the winter can reach -30 F for weeks in the peak of winter, I am considering making some minor improvements to the insulation and was wondering if putting up XPS polystyrene over both the fiberglass and the slats before putting up the drywall would be an appropriate way to go, or is there another option? The studs are 2X4s and with so much other work to do I want to keep the cost low and finish it quickly.
mnhockeydude is offline   Reply With Quote
Old 07-07-2013, 09:26 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 906
What is the exterior of the building currently?
Some pictures of the exterior and interior wall details will help illicit more responses.
Tags
insulation , old house remodel , xps
Insulating your attic Bob Mariani How To Guides 5 07-07-2013 09:49 PM
Our home remodel BFEdenizen Project Showcase 4 03-01-2013 06:41 AM
New home construction.. Small attic minimal insulation Robert95z Insulation 9 06-12-2012 01:27 AM
Basement Ext Wall - Will Rigid Insulation allow my wall to dry inward? COLORADOMTNMAN Insulation 10 01-15-2012 11:09 PM
Old Home - Basement addition insulation vapor barrier question 1870 Building & Construction 0 10-14-2010 08:36 AM
