No Vapor Barrier Above 1 Pc. Shower To Attic - Insulation - DIY Chatroom Home Improvement Forum
Old 05-04-2014, 08:21 AM   #1
No vapor barrier above 1 pc. shower to attic
I was just up in the attic inspecting for a real bad smell. When I pulled the 2 layers of batt insulation off from above the 1 piece shower, I noticed there was no vapor barrier under the insulation. It looks intentional.
There is vapor barrier there from the rest of the homes ceiling, that I can join to. I think it's necessary but I'm not sure? I live in Ontario, Canada. The 1 piece shower, backs onto an exterior wall which is log. The interior walls/framing are 2x4, no vapor barrier, and 3 of the 6 voids don't have pink batt insulation in them? The area looks dry, with no moisture damage.
My main question is should I vapor barrier above the shower?
Any help would be appreciated.
BigB is offline   Reply With Quote
Old 05-06-2014, 11:43 PM   #2
Registered User
Rewards Points: 526
Ask the local AHJ, most of that area requires the air/vapor barrier continuous...
Gary
PS. Welcome to the forums!
Old 05-17-2014, 02:28 PM   #3
Rewards Points: 127
continuous vapour barrier
wilyum is offline   Reply With Quote
Old 05-18-2014, 10:04 PM   #4
Rewards Points: 626
Yes most climate zones require a vapor retarder of 1 perm or less. and you are in the climate zone that requires it.
Nailbags is offline   Reply With Quote
Attic - Replacing electrical - Positioning, how many boxes, checking understandings darlingm Electrical 12 12-04-2011 11:17 PM
Raccoons in the attic electricpete Pest Control 17 05-12-2011 04:02 AM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 12:31 PM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 09:10 AM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 10:42 AM
