Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 01-27-2013, 11:16 AM   #1
Newbie needs help insulating attic
I have a roughly 1,000 sq. ft. attic that I want to reinsulate. I am a total novice when it comes to this and am not generally handy so I would appreciate some help. There is old batted insulation on the attic floor. It has eroded down over the years to about an average of 3 or 4 inches below the tops of the floor joists. My first question is, should I remove all of it or leave it in place and put the new insulation on top? There is a paper barrier on the upper side of it.
Secondly, regarding the decision of blown inulsation vs. batting, I think I am leaning towards batting because it's cheaper. Also it seems the batting would be easier to pull off than the blown stuff. Any advice on this?
Next, I've been reading about the importance of air sealing. Does this mean I'm going to have to lift up each section of the existing insulation and check for spots which need sealing?
Here is what the old stuff looks like. Thanks for your help!
Newbie needs help insulating attic-img_5276.jpg   Newbie needs help insulating attic-img_5277.jpg
JJfromNJ is offline   Reply With Quote
Old 01-27-2013, 11:38 AM   #2
#1 Go back and add your location to your profile so someone can help you.
#2 The insulation you have now is up side down.
Vaper barrier goes toward the conditioned surface.
#3 Going to have to seal up any place wires where run through the top plates and around any light or fan penatrations.
#4 Need to add foam or plastic baffles so the new insulation does not cover up the soffit vents.
Blown in would work best.
Buy 10 bags and any of the box stores will let you use the blower for free.
http://www.energystar.gov/index.cfm?...sulation_table
Dave Sal (01-27-2013)
Old 01-27-2013, 01:46 PM   #3
Dave Sal's Avatar
If you decide to use batts, make sure that the side with the vapor barrier is on the bottom, as joecaption mentioned. Buy yourself a one piece Tyvek painters suit and a dust mask and goggles. Tape the ankles and wrists to prevent the fiberglass particles from entering those areas. Fiberglass is nasty stuff and itches like crazy. You also don't want to breath that stuff.
Dave Sal is offline   Reply With Quote
Old 01-27-2013, 02:02 PM   #4
Nest Home Improvement
NestHI's Avatar
You may want to flip the existing insulation so that the vapor barrier is closest to the conditioned space. While doing that check for any gaps that need sealing. Finally, either do blown in or unfaced batts.
Home improvement simplified! Serving the Triangle (Raleigh, Durham, Chapel Hill). Please visit us at
NestHI is offline   Reply With Quote
Old 01-27-2013, 02:03 PM   #5
I'm located in New Jersey. I can't believe the old owners had it upside down the whole time. I still don't know if I should get rid of the old stuff or flip it right side up and put it back in under the new insualtion.
Old 01-27-2013, 02:15 PM   #6
NestHI's Avatar
It depends on the current state of the insulation whether to turn over or remove and replace completely.
Old 01-28-2013, 10:41 AM   #7
Sorry, a correction, the existing insulation actually has a double vapor barrier, so there is paper on the conditioned surface as well add the visible side. Is it counter productive to have a double barrier like this?
Old 01-28-2013, 11:02 AM   #8
Windows & Remodeling
HomeSealed's Avatar
Looks pretty nasty, I'd trash it all, air seal, and blow in new cellulose.
HomeSealed is offline   Reply With Quote
Insulating attic with HVAC maximusek Insulation 4 12-09-2012 09:23 PM
Advice insulating a finished attic wall jvetter713 Insulation 2 09-22-2012 11:56 AM
Insulating finished attic mudpaws Building & Construction 2 06-30-2012 01:51 AM
finishing insulating attic Roundeye Insulation 12 01-12-2012 10:10 PM
Newbie questions on refinishing walkup attic with knee walls FileOpen Insulation 2 11-20-2011 12:31 AM
