New To Basement Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 12-14-2012, 10:53 PM   #1
Rewards Points: 141
New to Basement Insulation
My new Raise Ranch House Basement has 9' ceilings {w/ knee wall}
what would be the best Insulation to use on the knee wall? I'm planning on fishing the basement some time what would be best to use for the concrete area ? Would I get better results by going with 2'x4' studs for the bottom part and use batten insulation what value should I get?
Taunton MA.
bote110 is offline   Reply With Quote
Old 12-15-2012, 10:59 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 2,048
There are a ton of threads about kneewall insulation approaches but rigid foam seems to be the best. Make sure it is done according to code.
Old 12-18-2012, 07:21 AM   #3
Rewards Points: 141
Talking to my contractor , he has advise me to use r21 for the kneewall and wall for the basement. Will start on the kneewall first because I framing the 5' wall later.
Old 12-18-2012, 08:22 AM   #4
Being a contractor does not make him an authority on insulation and proper weatherization techniques.
If you are insulating this area, you would be well served to read any of the countless threads on air sealing, kneewalls, etc.
Old 12-19-2012, 12:10 AM   #5
Rewards Points: 141
My contractor has to pass inspection from the the building inspector for our town so he should know what is to be use for our town laws in MA.
Old 12-19-2012, 02:30 AM   #6
My point wasn't whether you contract know code, but if he/she knows what is considered best practices and materials.
Code is easy.
http://publicecodes.cyberregs.com/ic..._11_sec002.htm
Basement Exterior Above Grade Insulation purpasadu Building & Construction 6 02-28-2012 05:42 PM
Insulation in basement floor joists and integrated garage speedster1 Building & Construction 3 12-07-2010 06:44 PM
Old Home - Basement addition insulation vapor barrier question 1870 Building & Construction 0 10-14-2010 08:36 AM
basement insulation advise needed bmartin5150 Building & Construction 1 04-27-2009 05:56 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
