New Addition...is It Insulated Properly?!? - Insulation - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-19-2011, 07:06 AM   #16
Rewards Points: 582
Originally Posted by Canucker View Post
I disagree. There is more than one way that is right, we need more info from her before we can help. Is the addition insulated? As GBR pointed out, is the crawlspace sealed off or is it vented? Where is she located? If the ductwork is sending enough hot air and the room is properly insulated, the better way would be to make the crawlspace a conditioned space by insulating the walls of it, if possible. That way the floors stay warm, the pipes stay warm because the concrete isn't acting like a heatsink, pulling the heat from inside the house through the rim and floor joists. Hot air rises, heat moves toward cold.
while that is true the way it is now is wrong....so my way to insulate would be right..
Old 12-19-2011, 07:29 AM   #17
Rewards Points: 282
Originally Posted by DIYChick45 View Post
Hey thanks Gary. That's SUPER helpful. I guess basements are difficult to insulate because of the moisture issue.
How would I attach the ridged foam to the block walls in the crawlspace? I think some caulking/glue will eat the foam if I'm not mistaken.
Thanks!!!
DIY, I am doing a similar project, check out my other topic's. There is a specific sealant that is used to attach the foam-board to the foundation/block wall. In fact I just picked some up this weekend at HD. There is also foundation screws you can use as well if needed.
Also be sure to get down there and seal up/air tighten the crawl space. By this I mean turn out the lights and move around in there and if you can see any light from outside seal up those area's as obviously air is getting in. Seal up the rim joists as well, they were a big factor for me and completely letting air in.
cbaur88 is offline   Reply With Quote
Old 12-19-2011, 07:33 AM   #18
Thread killer
Rewards Points: 272
I think my way is right. But I will agree, it's not right now
Canucker is offline   Reply With Quote
10x10 addition and raising floor 71Whaler Building & Construction 9 05-05-2011 01:28 PM
Bearing surface for joists - home addition benjamincall Building & Construction 6 04-05-2011 04:49 PM
Basement addition foundation questions hoggin03 Building & Construction 7 05-29-2009 07:28 AM
Soffits/gutters in 60s addition Project Diva Remodeling 1 05-10-2009 01:16 PM
Thoughts on this addition? sportinwla HVAC 13 04-20-2009 04:12 AM
