Need Insulation, What Is The Best - Insulation - DIY Chatroom Home Improvement Forum
Old 11-19-2011, 06:38 PM   #1
need insulation, what is the best
I have am getting a new roof 11/23/11 on the addition of the house. It needs installation as well. The roof is over the family room and eat-in part of the kitchen. What is it I need to know about the installation? size, weight, or some kind of... Well I went to HD and it had R30 R19 on pink panther rolls of installation, what is the difference? What is the best? It is going in the ceiling and I want to cut down on these heating bills. The bills in Michigan during the winter are as large as a house note ($500-800 a month). help please!
misspink1908 is offline   Reply With Quote
Old 11-19-2011, 08:41 PM   #2
Rewards Points: 582
the difference between them is the insulating value R30 is the better of the two ..will insulate your attic area comes in 24"wide and 16" wide ...
The Following User Says Thank You to ben's plumbing For This Useful Post:
misspink1908 (11-19-2011)
Old 11-21-2011, 12:05 AM   #3
Registered User
Rewards Points: 526
Depends on your location in Michigan, find your Zone below the map: http://publicecodes.citation.com/ico...001_par001.htm
Find your ceiling insulation requirements with your Zone here: http://publicecodes.citation.com/ico..._11_sec002.htm
Either R-38 or R-40. Read this on air sealing the attic before insulating; http://www.google.com/url?sa=t&sourc...wWATQw&cad=rja
And ventilation: http://www.buildingscience.com/docum...on?full_view=1
Figuring your venting requirements: http://www.airvent.com/homeowner/pro...it-specs.shtml
Will the roofer be installing ridge vents or soffit vents, or are they pre-existing?
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
misspink1908 (11-25-2011)
Old 11-25-2011, 11:10 AM   #4
Thanks Gary!!!!!!
Old 11-25-2011, 01:04 PM   #5
Sorry it took so long. This roof is over an addition eat in part of the kitchen and the family room it has no vents but a Breath stack thingy.
Old 11-26-2011, 12:15 PM   #6
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,244
A picture is worth a thousand words in this case.
Attic insulation over old attic floor beffreyj3 Insulation 6 11-18-2011 07:21 AM
Which insulation? Photos attached of room homiefb Insulation 1 08-16-2011 05:44 AM
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 08:14 PM
Has anyone used Green Fiber blown in insulation? pomelo Building & Construction 7 02-10-2010 07:17 AM
