Need Help With Workshop - Insulation - DIY Chatroom Home Improvement Forum
Old 05-18-2013, 07:57 PM   #1
Need help with workshop
I have a small 12x32 garage with a lofted attic. It is 2x4 walls. I lie in the desert and want to insulate as much as possible from the crazy summer heat, and cold winter nights. I would like to know if I can use 3/4" foam board next to exterior sheathing, than 3.5 inches of fiberglass. I know the fiberglass will compress a little bit. Is this ok or should I use the silver Bubble wrap stuff instead of the foam board?
Should I Use foam board or bubble wrap for the celing, closest to the crawl space?
And what about the loft. Same question. Foam board or silver bubble wrap up against the roof with insulation filling the cavity?
I really want to maximize insulation so I my AC doesn't work so hard when I am working in there. Thanks
If there is anything I haven't thought of please point it out. I have more energy than brains.
thefishkiller is offline   Reply With Quote
Old 05-18-2013, 08:15 PM   #2
Rewards Points: 14,290
Loose the loft and put up a real ceiling with insulation.
Make sure there's a ridge vent and soffit vents.
2 X 4 will not give you the needed room to properly insulate. There can be built out with 2 X 2's.
http://www.energystar.gov/index.cfm?...sulation_table
Old 05-18-2013, 08:19 PM   #3
It is a real ceiling. By loft I just mean its an attic you can almost stand up in. there is already plywood on top of the roof rafters. the roof and celing are 2x8.
Old 05-19-2013, 05:43 AM   #4
Then use R 19 in the ceiling and cover with drywall.
Just sealing off that attic space from the conditioned envelope will make a huge differance.
Old 05-19-2013, 06:01 PM   #5
Registered User
Rewards Points: 526
Some other options; http://www.buildingscience.com/docum...rchterm=attic+
http://www.buildingscience.com/docum...n-roof-venting
Solar chimney, pp.18; http://www.buildingscience.com/docum...n-technologies
This should keep you busy a while, lol; http://www.buildingscience.com/docum...ifornia-attics
Figure 10% less shingle life for unvented; http://www.buildingscience.com/docum...on?full_view=1
Asphalt shingles/foam thickness for Zone 3, Table 4: http://www.buildingscience.com/docum...study-analysis
Radiant: http://www.mytexasinspector.com/pdf/...heet%20DOE.pdf
Gary
PS. Welcome to the forums!
Workshop requirements in Ontario macman44 Electrical 5 01-17-2013 10:57 PM
Subpanel to outdoor workshop RM575 Electrical 22 08-01-2012 09:59 PM
Subpanel for the workshop avgor Electrical 5 04-09-2012 07:56 PM
help - flooded workshop - what to do??? Allthunbs General DIY Discussions 5 03-19-2011 07:36 PM
Workshop Panel Grounding/Bonding IdahoBob Electrical 3 01-29-2007 11:13 PM
