Is My Attic Insulation Adequate? - Insulation - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-20-2014, 09:22 AM   #16
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,760
You do need an airtight enclosure around the attic stairs. They sell them or you can make your own.
Old 02-20-2014, 05:52 PM   #17
Registered User
Rewards Points: 5,516
Mike, you really can't compare them. IMO, batts are for limited headroom, cathedral ceilings, or over a bath fan for future replacement. The batts are fine for low slope (restricted headroom and lower insulation dams around scuttle hole access), around recessed lighting without building a cover or with standard joist spacing, but blow-in is easier with multiple obstructions. IMO, need an elevated walkway for any HVAC - OR (removable) batts just from the attic scuttle to unit for filter changes. Just raking blow-in aside for access and replacing leaves big air pockets (de-rating the R-value) because the insulation clumps up with further movement.
The FG batts are available in much higher densities than the blow-in for perimeter application where roof slope interferes with full R-value. You don't want the insulation touching roof sheathing or even framing (R-1.25 in wood-- thermal bridge)- premium to use stacked/sloped (baffles of XPS) rigid foam board over the exterior walls (1' wide) for maximum insulation in that restricted height- no conduction loss. Use of blown-in FG = R-10 at that 4" height and this is the coldest wall in the house (due to exterior location and air vents directly coupled above).http://bct.eco.umass.edu/publication...o-save-energy/
There are recirculating convective loops in all gabled attics that are vented- the cold incoming air sinks to/through the top inches of blown-in quite easily due to the low density- mixing with the heat flux rising from room below; http://digitalcommons.unl.edu/cgi/vi...ct%3Dj%26q%3Dv
The more insulation you add, the better it is as the density increases from the weight above = better product. Still, even at R-60, the density is only 0.58#ft.cubed;http://www.r-prollc.com/Documents/At...Fact_Sheet.pdf
Your local code requires R-38; http://energycode.pnl.gov/EnergyCode...state=Nebraska --------------- Six-sided air barrier required for full R-value; https://docs.google.com/viewer?a=v&q...M8l_EeA2F-qvvA
So, to counter the convective loops and the attic wind-washing, IMO add a housewrap over the top- like Tyvek as it will also work as a radiant barrier of sorts;http://www.homeenergy.org/show/article/year/1992/id/895
Or from above, at new construction; http://www.philwrites.com/AW_Manual_12_1_all_LR.pdf
Gary
PS. OR just fill it to R-60...lol.
The Following User Says Thank You to Gary in WA For This Useful Post:
Mike68847 (02-21-2014)
Old 02-20-2014, 09:46 PM   #18
Jb1234's Avatar
Rewards Points: 87
I believe my brain just imploded trying to fully understand this.
Jb1234 is offline   Reply With Quote
The Following User Says Thank You to Jb1234 For This Useful Post:
joecaption (02-20-2014)
Old 02-21-2014, 06:52 AM   #19
Rewards Points: 36
Thanks everyone for all your comm,wents and suggestions. I'm learning a lot.
Mike68847 is offline   Reply With Quote
Old 02-22-2014, 08:58 PM   #20
Registered User
Yes, I've used that link to show convective loops are always in an attic (with passive venting), cold------ ; or hot climate; http://www.fsec.ucf.edu/en/publicati...SEC-PF-226-91/
Now I'm trying to convert the heat flux (using same outside temps) through the attic insulation (R-20) compared to heat through a 2x4 (R-13) exterior wall-- pp.86: http://www.google.com/url?sa=t&rct=j...,d.cGE&cad=rja But the wall outside temp is 5*F, with 10 W/m2 loss and the ceiling (R-20) with 32*F outside and 37 W/m2 loss, and 21*F out with 48 W/m2 loss; almost 5 times more loss and temps are warmer in attic (w. 4cm vents) than wall exterior..... anybody?
Send me a PM if you want, I'd love some help on this. Thanks, Gary
PS. the colder air (less dense) settles on the attic floor being warmed by the heat loss through the insulation to rise/exit the high vents; http://learn-science.20m.com/tmyths.htm#myth2
http://www.usatoday.com/tech/columni...derquest_x.htm
Old 03-01-2014, 06:40 AM   #21
If you know of any painters, an extendable and retractable painters pole is handier than a pocket on a shirt for blowing in insulation. Duct taped to the blower hose and you're GTG.
Queefer is offline   Reply With Quote
Old 03-02-2014, 12:53 PM   #22
Rewards Points: 626
going from R-19 to R-49 is not that costly. Once you have blown in that is what you need to stick with. you can have batts then cover with blown in but not the other way around.
Nailbags is offline   Reply With Quote
Old 03-02-2014, 12:56 PM   #23
Rewards Points: 626
Huh? translate to laymen's terms please
Old 03-02-2014, 07:18 PM   #24
Registered User
It's all temperature differences; http://www.uwgb.edu/dutchs/EnvirGeol...EarthWorks.HTM
Warm air enters attic, colder air settles in your blown-in insulation. Convective currents formed by temp difference degrade any ceiling insulation without a cover on top or enclosed venting continuous to the ridge.
Which width for insulation rolls
Gary
Old 03-08-2014, 07:16 PM   #25
Rewards Points: 410
With an infrared gun (Lowes has em cheap) I've seen the temp fluctuations (from air currents in my glass insulation) while aimed at the ceiling and the colder it is the wider the fluctuations.
I'm at min code here with blown R38 glass ...will upgrade to R60 I think and the link about the tyvek covering sounds like a great idea.
Great thread !
High Gear is online now   Reply With Quote
Old 03-10-2014, 05:46 PM   #26
Originally Posted by joecaption View Post
Not enough. http://www.energystar.gov/index.cfm?...sulation_table
Need to check to see if anyone air sealed before adding the insulation that's there.
Sealing up anyplace plumbing, wiring lighting was run into the attic with spray foam will be a big help.
If someone added can lights make sure there IC and air tight fixtures. If not your going to have to add some covers.
Can the OP use any type of spray foam?
225714 is offline   Reply With Quote
Old 03-11-2014, 01:10 PM   #27
Great thread !
R38 is code.
There is a diminishing law of return on depths beyond that really but insulation is relatively cheap.
Tyvek does stop the wind washing but if you install cellulose, it is denser to begin with.
FYI...what you have is a Infrared Thermometer.
Tags
insulation , r-value
Can/should I add insulation underneath stationary stairs to my attic? Bitruder Insulation 3 12-28-2012 11:04 PM
Attic Insulation Help Needed-What type, etc HandyFrank Building & Construction 9 12-15-2011 01:54 PM
Blown in insulation for un-insulated attic Cubey Insulation 10 10-19-2011 07:08 PM
Adding attic insulation pomelo Building & Construction 3 10-22-2009 05:19 PM
Insulation over Attic Walkway BigJimmy Building & Construction 4 06-23-2008 02:13 AM
