Is My Attic Insulation Adequate? - Insulation - DIY Chatroom Home Improvement Forum
Old 02-19-2014, 08:17 AM   #1
Rewards Points: 36
Question
Is my attic insulation adequate?
Our house is in central Nebraska. Utility bills aren't outrageous, but I wonder if I can do better. The house is about 12 years old and we're ther second owners. In the picture below, the insulation is about 6-8" deep. Any comments or recommendations?
Mike
central NE
Mike68847 is offline   Reply With Quote
Old 02-19-2014, 08:21 AM   #2
Rewards Points: 13,468
Not enough. http://www.energystar.gov/index.cfm?...sulation_table
Need to check to see if anyone air sealed before adding the insulation that's there.
Sealing up anyplace plumbing, wiring lighting was run into the attic with spray foam will be a big help.
If someone added can lights make sure there IC and air tight fixtures. If not your going to have to add some covers.
Old 02-19-2014, 09:04 AM   #3
Rewards Points: 36
Thanks for the info. Any advantages to blown ("fluffy") vs. rolls of insulation?
Old 02-19-2014, 09:07 AM   #4
Blown in is better and less expensive.
Lowes and Home Depot will let you use there blower if you buy 10 bags for free.
Old 02-19-2014, 09:13 AM   #5
Rewards Points: 36
Great! I didn't know that.
Old 02-19-2014, 09:21 AM   #6
Going to need two people, make sure to pick up some dust mask. One down stairs loading the other in the attic blowing.
I find it works best to have the blower sitting on a 12 X 12 tarp to reduce the clean up time. It's messy stuff to try and just rake up.
Do not cover up the area that extends out over the walls with out adding foam baffles first.
You need air flow from the soffits to the roof vents.
http://www.bing.com/images/search?q=...lectedIndex=39
I've found it easier for me if I duct taped a piece of 3" PVC pipe to the flex hose on the blower. That way I can stay in the middle and hit the sides without having to even bend over.
Jb1234 (02-20-2014)
Old 02-19-2014, 09:34 AM   #7
Rewards Points: 36
Thanks again. More stuff I didn't know.
Old 02-19-2014, 09:38 PM   #8
Rewards Points: 236
round here, its 20 bags at HD. idk about lowes. and menards charges no matter what.
Fix'n it is offline   Reply With Quote
Old 02-20-2014, 03:32 AM   #9
Rewards Points: 36
Thanks, Good to know this in advance.
Old 02-20-2014, 03:49 AM   #10
Mr
When installed properly, loose-fill insulation improves the energy efficiency of a home, lowers utility bills and decreases carbon dioxide emissions...
MikoMcGreg is offline   Reply With Quote
Old 02-20-2014, 07:29 AM   #11
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,238
Add some more and you are good.
Air sealing is great too if you can at least get the big stuff.
The Following User Says Thank You to Windows on Wash For This Useful Post:
Mike68847 (02-20-2014)
Old 02-20-2014, 08:31 AM   #12
Rewards Points: 54
Why is blown in better? Batts are batts and cannot manipulated based on installation. Blown in can by the installer, so although you have 20 inches, if there is too much air it will settle, correct?
If you need access, batts are easier too move and work, except in the case were blown in is your bottom layer.
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 02-20-2014, 08:35 AM   #13
Blown in is easier to install, easier to get more uniform coverage, tends to settle into crevices more effectively and self level, etc.
Fiberglass doesn't settle and cellulose does a bit but its overall R-Value doesn't really change as a result.
You shouldn't need to be in the attic that much and I would plan on getting everything done that you want to first, then insulate.
Old 02-20-2014, 08:42 AM   #14
Rewards Points: 54
One thing that is always overlooked and the easiest to insulate and closes a huge hole, is the attic staircase. I read a report a while back that you can do all of the attic insulating correctly, but if you do nothing to the attic stairs you have left a huge void that impacts by reducing your insulations benefits by 30 percent I believe.
Old 02-20-2014, 08:54 AM   #15
Jb1234's Avatar
Rewards Points: 87
Your attic looks almost exactly as mine. My plan was to do the blown in this spring. Great tip Joe about adding the PVC pipe to the front.
Jb1234 is offline   Reply With Quote
Tags
insulation , r-value
Can/should I add insulation underneath stationary stairs to my attic? Bitruder Insulation 3 12-28-2012 11:04 PM
Attic Insulation Help Needed-What type, etc HandyFrank Building & Construction 9 12-15-2011 01:54 PM
Blown in insulation for un-insulated attic Cubey Insulation 10 10-19-2011 07:08 PM
Adding attic insulation pomelo Building & Construction 3 10-22-2009 05:19 PM
Insulation over Attic Walkway BigJimmy Building & Construction 4 06-23-2008 02:13 AM
