Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 05-29-2012, 02:12 PM   #1
Trucon01's Avatar
Must you secure XPS foam to basement walls?
Hi All,
I plan on insulating my basement with 2" XPS foam over the concrete block walls. Should I secure the foam to the wall with some PL300 or can I just frame up against it and let the wood hold it in place?
Basement Demo started Jan 2012:
Bathroom demo started Feb 2013:
Trucon01 is offline   Reply With Quote
Old 05-29-2012, 02:27 PM   #2
Exterior Construction
Windows on Wash's Avatar
If you are framing it up soon thereafter, you don't need a ton of glue.
Just stick it to the wall and makes sure that you shim it tight against the framing once you finish out the framing portion of the project so there is some force applied to the foam to keep it tight to the wall.
Old 05-29-2012, 02:31 PM   #3
Trucon01's Avatar
Thanks Eric!
Old 05-29-2012, 03:38 PM   #4
Yep!
Take me to play Westfields and we will call it even.
Old 05-31-2012, 01:55 AM   #5
Moderator
It's imperative to air-seal the concrete from the room air; http://joneakes.com/jons-fixit-database/743 (From one of our new members)!
Pages 8, 11, etc.; http://www.buildingscience.com/docum...lation-systems
Sill sealer under the p.t. bottom plate (air/thermal/capillary break), ADA the drywall, everything to keep that room air from the cold concrete: http://www.buildingscience.com/docum...wall-approach/
Gary
Clothes taking longer to dry?
Old 05-31-2012, 12:43 PM   #6
Trucon01's Avatar
Thanks Gary.
Off the subject a little bit, I plan on cutting in an interior weeping tile system against the footer. Should I use one of those dimpled membranes against the wall and then the XPS insulation or not even bother with the membrane?
Old 05-31-2012, 02:22 PM   #7
Jeff,
I will renew my offer to take a look at it for you but I am pretty firmly convinced that you will be wasting your money if you do that. I think most of your issues are drainage and condensation related. Fix the gutters ant the wells and you will be fine.
Old 06-01-2012, 01:58 PM   #8
Moderator
No, glue the f.b. directly to the concrete wall with vertical beads only, not to trap moisture. continuous bead along top edge, Enka (or similar) at concrete wall/new slab joint and under replaced area for drainage, Fig. 15; http://www.buildingscience.com/docum...lation-systems
Gary
Old 06-01-2012, 04:02 PM   #9
Architectural Designer
AGWhitehouse's Avatar
The underlined statement is in direct conflict with your first link. It states to place glue in a grid pattern to mitigate convective currents...
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 06-02-2012, 12:29 AM   #10
Moderator
In post #6, Trucon01 added a different scenario, I changed-up and switch hit because the new slab drain is linked to the concrete wall for clear drainage. Horizontal glue beads would create ledges for the moisture to pocket and soak in to the foam board. Price you pay for draining there, a slight R-value reduction. Glad you read the links though, nice catch!
Gary
Foam Insulate All Basement Walls? VikingDinKC Remodeling 44 01-30-2012 10:43 PM
Can I run electrical wire BEHIND my basement walls? GoBengals Electrical 8 01-18-2012 09:38 PM
Basement Ext Wall - Will Rigid Insulation allow my wall to dry inward? COLORADOMTNMAN Insulation 10 01-15-2012 11:09 PM
Spray foam or rigid for basement walls? upinsmoke Building & Construction 6 05-02-2010 05:23 AM
Best Foam for Basement Walls? heybrady Remodeling 5 08-19-2008 11:31 AM
