Moisture In Crawl Space - Insulation - DIY Chatroom Home Improvement Forum
Old 07-03-2012, 11:56 AM   #1
Moisture in crawl space
We own a summer camp in Maine that we rent out. The house is about 30 years old. We close the house up after Labor Day and Open it up on Memorial Day so no one occupies it during cold weather (we also get our water from the lake). The crawl space varies between 3-4 feet from the ground to the bottom of the joists. There is a 6 mil plastic barrier covering the ground. There are 8 ventilation openings around the foundation. The house originally had insulation between the joists as the original owners stayed into the start of cold weather. I have just had to pull out all of this insulation as the barrier of it has mold, the joists have dampness penetration marks about 1/4 of the way up them, there is moisture on the concrete foundation and dripping from the romex cabling!! This problem lasts during the short periods of humidity in the spring and early summer. I am thinking about buying plastic to staple to the bottom of the joists and not replace the insulation as no one is in the house in cold weather. My thoughts are that the plastic will protect the joists as well as the romex wiring. I would also wrap the plastic around the 4X4 supports. Will this solve the problem?? ANyone's thoughts are appreciated
Coke99 is offline   Reply With Quote
Old 07-03-2012, 12:48 PM   #2
Rewards Points: 14,312
No that would trap the moisture in there and cause mold and fungus to grow even faster.
Just a guess is the crawl space lower then the outside grade?
I'd also guess there's no gutters on this building.
Is the area around the foundation higher then the surrounding grade?
Old 07-04-2012, 02:03 AM   #3
Rewards Points: 1,092
I'd suggest you read on buildingscience.com about crawl spaces. Absolutely do not install that visqueen, as joe said. If you ever want to insulate, install rigid foam on the bottom of the floor joists and seal them up real well. Also, close the vents so you can heat (condition) the crawl space when you are there heating the place.
Old 07-04-2012, 07:56 AM   #4
That sure sounds like what you've got is your more-humid summer air entering the crawl, which is cooler enough to let the moisture literally dew right out of the air.
as already said, plastic on the bottom of the joists would make it much, much worse. Assuming you've got really good plastic down, the answer is probably to seal the vents and condition the space. Check with local code office, as you might be able to run a dehum easily and inexpensively, or you may have to use hvac air.
CrawlSpaceMoist is offline   Reply With Quote
Old 07-04-2012, 09:44 PM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,592
Time to seal up that crawl and/or contact a spray foamer (preferably someone who know what they are doing).
Old 07-05-2012, 12:55 AM   #6
Registered User
Rewards Points: 526
http://www.buildingscience.com/docum...n-crawlspaces/
In the vinyl areas just use f.g. and housewrap.
Gary
Odor from Crawl Space G Ollis General DIY Discussions 68 11-02-2013 01:31 AM
excessive moisture in attic crawl space jimmy21 Building & Construction 11 02-19-2012 02:46 AM
Crawl space moisture/water removal KAdams4458 Building & Construction 7 04-24-2011 12:21 PM
Water in crawl space after it rains and other questions about crawl space. dupaloop General DIY Discussions 1 04-13-2010 05:58 AM
Crawl Space Insulation skinny2 Building & Construction 10 12-12-2008 11:36 AM
