Moisture Between Foam Board And Roxul - Insulation - DIY Chatroom Home Improvement Forum
Old 01-27-2014, 05:15 PM   #1
Rewards Points: 776
Moisture between foam board and Roxul
Last week I put foam board against the cement wall in the basement and sealed it. The walls are studded in and I put Roxul in between the studs.
Yesterday I was showing my son-in-law how I did it and as I pulled a batt of the Roxul out, I noticed there is moisture in the Roxul where it was in contact with the foam board.
Did I do something wrong?
gma2rjc is offline   Reply With Quote
Old 01-27-2014, 06:09 PM   #2
Rewards Points: 173
How thick is the board?
RCGA is offline   Reply With Quote
The Following User Says Thank You to RCGA For This Useful Post:
Gary in WA (01-27-2014)
Old 01-27-2014, 06:15 PM   #3
Rewards Points: 14,290
Still no vapor barrier on the studs and no drywall up so the moisture can still form against the unheated wall.
Old 01-27-2014, 09:02 PM   #4
Rewards Points: 776
It's 3/4" thick.
Thanks Joe. Will moisture get trapped between the foam board and the poly? There won't be a vapor barrier at the very top of the space between the 2x4's, so maybe moisture can get out that way (?).
I'll be removing the Roxul that's already in place and running a fan to let things dry out, then replacing it before putting up the 6 mil poly.
Old 01-28-2014, 07:22 AM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,554
If the walls aren't up, its not at all surprising.
I still would not use poly and you need more foam at the wall than just 3/4" (not sure what you used here either but the max R-Value you have is R-4 and that just isn't enough).
The Following User Says Thank You to Windows on Wash For This Useful Post:
gma2rjc (01-28-2014)
Old 01-28-2014, 02:13 PM   #6
Registered User
Rewards Points: 526
Which Zone?; http://energycode.pnl.gov/EnergyCode...state=Michigan
Eg. Grand rapids; R-5 (1"XPS) + R-15 = at 68*F room air, safe to only 37% Relative Humidity at the above-grade/2' down areas.
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Old 01-28-2014, 08:27 PM   #7
Registered User
Rewards Points: 526
Since you thanked me, is that the correct Zone? Lol.
Gary
Windows on Wash (01-28-2014)
Old 01-28-2014, 08:31 PM   #8
Rewards Points: 776
Yes, that's the correct zone. Thanks so much for your help Gary!
Barb
Old 01-28-2014, 10:32 PM   #9
Registered User
Rewards Points: 526
You're welcome. We are here to serve. ADA the drywall, it will help immensely in keeping any air from the cold concrete, esp. if you didn't apply glue in 1' square grid pattern or can foamed the perimeter of the sheets. Remember the rims; foil-faced fb/canned foam-low expanding- more for the $. http://www.buildingscience.com/docum...m-at-rim-joist
http://www.buildingscience.com/docum...wall-approach/
http://joneakes.com/jons-fixit-database/743
The degree of air tightness is imperative, not even 1/16" gap anywhere..... yikes!
Gary
Old 01-28-2014, 10:51 PM   #10
Registered User
Rewards Points: 526
BTW, the Grand Rapids was using the average of 3 coldest months of the year, so with the 3/4"---if XPS- you should be OK for most of the year. The above grade foam board code requirements for Zone 5--- to prevent cavity condensation is; http://www.buildingscience.com/docum...r-requirements
If adding fibrous insulation FG/Roxul at the rims; use 2" FB with only enough Roxul to meet (wall) code- the more you add= the less ability fb has to prevent condensation because the colder it is; lowering it's dew-point temperature, Fig.3, 4- adding cavity insulation, notice the R-value changes= dew-point changes; http://www.buildingscience.com/docum...nsulation/view
Gary
Old 01-28-2014, 11:43 PM   #11
Rewards Points: 776
Thanks again Gary. Buildingscience.com has a ton of helpful information.
I didn't know Jon Eakes has a website. I used to watch his show on tv, but haven't seen it in at least 6 years.
Old 01-29-2014, 10:22 AM   #12
Registered User
Rewards Points: 526
I knew he had a website but not a tv show.... lol. He is a member here.... hasn't chimed in for a while though.
Gary
Old 01-30-2014, 12:45 AM   #13
Rewards Points: 776
I think it's called 'Ask Jon Eakes'. He has a few videos on YouTube.
The Following User Says Thank You to gma2rjc For This Useful Post:
Gary in WA (01-30-2014)
Rigid (XPS) Foam Board Size for basement. fastmodena Insulation 6 12-03-2012 09:42 PM
Installing foam board around windows ? Arky217 Windows and Doors 3 09-12-2011 04:13 PM
foam board between joists fubar79 General DIY Discussions 17 10-05-2010 09:38 PM
rigid foam board and height ctkeebler Building & Construction 4 01-09-2010 02:42 PM
