Mobile Home Wall Insulation Tool - Insulation - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-21-2013, 07:11 PM   #16
Rewards Points: 626
Originally Posted by jigami View Post
Is it worth insulating the bottom portion of the trailer? There is no insulation there right now. I was thinking to put insulation on the tarp and nail the tarp to the bottom of the trailer.
in Arizona I do not think it is called for. Second how big is your Mobil? I have built sheds over moble homes and that has helped cut the heat down.
Nailbags is offline   Reply With Quote
Old 08-22-2013, 10:19 AM   #17
from inside the mobile home, there is carpet, then pading, and then plywood and then 2 by 4s running across.
so from the bottom of the trailer, i can see 2 by 4s and above that is the plywood.
jigami is offline   Reply With Quote
Old 08-22-2013, 10:21 AM   #18
it is long with several rooms. cover over it is not feasible
Old 08-22-2013, 11:29 PM   #19
Registered User
Rewards Points: 526
The lexan tool in the video was installing R-13 in the 2x4 walls.
R-30 @ 9-1/2" is compressed (by the manufacturer) to R-25 @ 8" and again compressed to R-21 @ 5-1/2" again comp. to R- 15 @ 3-1/2" each time the density increases as the thickness decreases = less R-value for the wall---- but the R-value per inch increases--- R-30 starts at 0.5#/c.ft. to R-25 @ 0.7#/c.ft. to
R-15 at 1.4 #/c.ft. : http://www.greenbuildingadvisor.com/...fiberglass.JPG
But, it would blow-out the wall metal or not install in enough to be effective. Density is of paramount importance in fiberglass batts to prevent convective looping, pp 45-47; http://www.buildingscienceconsulting...Measure_Up.pdf
R-19 (low density) is compressed to R-13 (medium density); pp. 68; http://www.buildingscience.com/docum...study-analysis
R-19 is the "biggest loser" of them all; The "biggest loser" in fiberglass insulation....
#7; Using attic insulation in interior walls.
Insulate under the living space as the ground there is close to the same temp as the ambient air temperature, along with radiation coupling, think reverse of this; http://www.buildingscience.com/docum...n-crawlspaces/
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
beenthere (08-23-2013)
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Power loss carlko Electrical 55 03-12-2011 05:26 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Hybrid wall insulation consisting of 2" rigid foam + 2x4 fiberglass batts? TitaniumVT Building & Construction 15 09-14-2010 02:50 AM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
