Metal Building Sweating - Insulation - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-25-2013, 11:41 PM   #16
Registered User
Rewards Points: 5,520
http://publicecodes.cyberregs.com/ic..._11_par002.htm
http://www.buildingscience.com/docum...rchterm=attic+
http://www.designandbuildwithmetal.c...h_7_13_09.aspx
Gary
Old 08-16-2013, 01:14 PM   #17
Rewards Points: 53
Moisture in metal building
I have a 25'W X 50'L metal building on a concrete pad that has a moisture problem. It is just steel tubing with metal sheets screwed on to it. I am wanting to fix my moisture problem. What would be the best way to do it? Insulate it? Install some fans to ventilate it?
tucker0104 is offline   Reply With Quote
Old 08-16-2013, 02:22 PM   #18
Rewards Points: 6,652
You already have a thread regarding this at Metal Building Sweating also Insulating a metal building and http://www.diychatroom.com/f19/seali...d-slab-146569/ Please keep it to one thread, then multiple on the same subject.
Old 08-16-2013, 03:25 PM   #19
An old Tradesmen
Rewards Points: 7,414
Merged threads.
The Following User Says Thank You to beenthere For This Useful Post:
gregzoll (08-16-2013)
Old 08-16-2013, 08:53 PM   #20
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,790
Originally Posted by beenthere View Post
Merged threads.
That...was awesome...
The Following User Says Thank You to Windows on Wash For This Useful Post:
Metal Studs in Metal building with horizontal support 7SistersRanchTX Building & Construction 1 03-06-2012 05:56 PM
Building a Metal vine covered pergola. dakkon Building & Construction 0 03-04-2012 08:10 PM
Can I frame with wood on a building instead of metal studs EHouse Kitchen & Bath Remodeling 4 01-12-2011 10:19 PM
Getting shocked by multiple metal items in room thms Electrical 14 06-24-2010 01:23 PM
Metal Roof Repair Questions bruce3404@hotmail.com Roofing/Siding 3 09-17-2008 10:00 PM
