Man Cave Inside Polebarn - Insulation Question - Insulation - DIY Chatroom Home Improvement Forum
Old 02-22-2013, 09:37 AM   #1
Man cave inside polebarn - insulation question
I am dividing up my 30 X 50 polebarn into a shop / storage side and a "man-cave" side. I have the outside walls studded and insulated with R-13. I'm planning on a drop ceiling for the man-cave side, but I want to add insulation above that.
I have attached a pic of what the roof looks like now. Can I just put some 1X2 blocking up between the trusses and put the R-30 insulation on top of that, or is the drop ceiling strong enough to just roll the insulation on top of it?
I appreciate any suggestions.
bkanneg is offline   Reply With Quote
Old 02-24-2013, 08:29 PM   #2
Rewards Points: 142
i don't see 1x2 holding up that much insulation. i would put 2x4's 16"oc. then drywall.
Fix'n it is offline   Reply With Quote
Old 02-25-2013, 01:24 AM   #3
Rewards Points: 1,092
roger that on the 2x4's, between or under the trusses. then, blow in cellulose and be done w/ it. air seal the sheetrock as best you can, and provide ventilation.
Old 02-25-2013, 11:24 PM   #4
Msradell's Avatar
Rewards Points: 88
If you install the drop ceiling with sufficient hanger wires, you should be able to just roll the fiberglass insulation out on top of the suspended ceiling. Just be sure that whatever light fixtures you install are rated IC.
Msradell is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Basement Insulation Question gilbo125 Building & Construction 9 02-01-2011 05:13 AM
blow in insulation question Cool user name Remodeling 4 12-31-2010 12:24 AM
Sheetrock And Insulation Question kn1564 Remodeling 4 04-23-2010 12:24 PM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 09:14 PM
