Low Crawl Space Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 09-30-2012, 06:33 PM   #1
Low crawl space Insulation
I have a room addition that is on a block foundation only two high. This was a paint studio and now wanting to convert into a bedroom. It is vented and there is no access under it. I remover the entire floor to insulate. Just wondering the best way. I will lay a moisture barrier for sure, however it appears very dry. There are heat ducts but no pluming. I was thinking about eliminating the vents and only insulating the exterior walls. Is this ok to do? I live in Ohio.
mhahn is offline   Reply With Quote
Old 10-01-2012, 09:40 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,794
They made a crawl space and gave no access to it?
Do you have some pictures?
Crawl Space/Foam Insulation DIY cbaur88 Insulation 9 12-08-2011 09:18 AM
Crawl space insulation questions Gates Building & Construction 3 01-26-2011 09:57 AM
crawl space insulation thevoz Building & Construction 6 01-10-2010 12:56 AM
Unvented crawl space insulation ehardman Building & Construction 3 01-13-2009 01:44 PM
Crawl space insulation howard.wheaton Building & Construction 10 10-21-2008 10:41 PM
