-   Insulation (http://www.diychatroom.com/f103/)
-   -   Living Room Wall (http://www.diychatroom.com/f103/living-room-wall-124160/)
aot2002 11-21-2011 10:17 AM
Living Room Wall
I have one wall in the living room to the outside of the building about 11 foot long and 8 foot high.
It was once a door way to the outside and was closed in apparently not that well done :(
The walls do not have the mil plastic between the sheetrock and studs like the new buildings are getting.
I believe it has R19 in the walls but because it's like 45 degrees and freezing I'm starting to wonder.
I'm going to redo it but since I just remodeled the inside of the living room tearing off the sheetrock is not an option.
I'm going to remove the siding and plywood from the outside to get access.
I used this method for another area but put in 2" Foam board with R-10 value turned out to not be super effective.
Question is :
Do I need to put in plastic on this one wall?
Should I opt for R19 faced instead?
If R19 is installed what other things can I do?
Should I install outside WRAP before closing it up?
any feedback would be great.
Windows on Wash 11-21-2011 11:38 AM
You need to be mindful of the vapor retarder levels and be sure that you don't have two on either side of the wall.
aot2002 11-21-2011 12:01 PM
Thanks I'm aware of the vapor retarder process can cause moisture in the walls, but I am also aware of a builder who puts on wrap on the outside behind the siding and 6 mil plastic behind the sheetrock.
This to me sounds bad.
Since my room doesn't have plastic behind the sheetrock I am opting for wrap on the outside since I am coming at this from the outside.
Also we only have cold walls on one wall so I might find the insulation is done wrong or something else bizarre.
Windows on Wash 11-21-2011 01:11 PM
Housewraps are not vapor barriers (Class 1 vapor retarder) in this case.
They are vapor permeable so drying can still happen to outside.
Depending on the foam that you use and the thickness, you will have a vapor barrier on the outside of the home.
If you don't have plastic beneath the drywall, you should be fine.
aot2002 11-21-2011 01:18 PM
Knowing that foam board is a lower R value (10) at 2" thick does it make more sense to use batts insulation and house wrap or just to install foam with the house wrap
Windows on Wash 11-21-2011 01:42 PM
http://www.greenbuildingadvisor.com/...-outside-house
aot2002 11-21-2011 01:50 PM
Originally Posted by Windows on Wash (Post 776213)
thanks I seen this online but I am using an existing structure and will be using foam inside of the cavity walls, I did this already on a outside porch while it helped it didn't stop all air but it didnt cut it down dramatically.
Windows on Wash 11-21-2011 02:49 PM
If you are removing the siding from the exterior, you should put a rigid foam across the exterior prior to re-siding to interrupt the thermal bridging and resultant drop in R-Value.
Using foam for inside the wall cavity is probably more trouble than it is worth between all the cutting and fitment. If you want to use foam, buy a 600 board foot spray foam kit and just spray the inside wall from the back side.
High density fiberglass or mineral wool is probably just as well.
I would put in cellulose, mineral wool, or unfaced fiberglass (high density), cover the exterior with a rigid foam, tape the seams, and re-side/cover.
Make sure you seal up the air barrier (drywall) from the backside with caulk/foam to prevent any air loss from the structure.
aot2002 11-27-2011 09:54 PM
I've posted some pics of before and after it's working real well now
BEFORE
http://imageshack.us/photo/my-images/193/img0035rj.jpg
http://imageshack.us/photo/my-images/39/img00341.jpg
AFTER
http://imageshack.us/photo/my-images/854/img00401.jpg
http://imageshack.us/photo/my-images/38/img00391f.jpg
