Living/Garage Wall And Spray Foam Install Question - Insulation - DIY Chatroom Home Improvement Forum
Old 04-02-2014, 09:14 AM   #1
Living/Garage wall and spray foam install question
I called to get some estimates on spray foam insulation and asked how they spray the foam for the common walls between the living area and the garage. They told me that the drywall is installed in the garage first and then they spray the foam. Drywall guys don't want to start the garage and wait for the spray foam guys to do the rest. Anyone have suggestions on how to get this done? I thought about using some of that 1/4" fan fold foam board to put on the garage side of the wall and have them spray the foam on that and then the drywall can be placed over the fan fold board.
Howard
HowardBrown is offline   Reply With Quote
Old 04-02-2014, 10:13 AM   #2
Rewards Points: 13,300
Need more info.
Is this a new constructed house, or a garage being added to a house?
If I was going to make a mess with spray foaming a wall I'd want the mess in the garage not inside the house.
Old 04-02-2014, 10:30 AM   #3
Sorry, new construction. All I have up now is the framed walls. Garage is attached.
Old 04-03-2014, 02:59 AM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 2,022
Don't use the fan fold board but if you want some rigid board, that should work.
Old 04-03-2014, 10:56 PM   #5
Registered User
Rewards Points: 5,244
Faced, on garage side only- Fig.3-41; http://books.google.com/books?id=Eq1...page&q&f=false
ADA the drywall on garage side to keep the hot moist air from condensing on the cold studs (R-1.25 per inch) from AC; http://www.buildingscience.com/docum...wall-approach/
Gary
PS. do the lid if living space above, Fig.7; http://www.buildingscience.com/docum...n-crawlspaces/
XPS Foam on uneven basement wall - Pt.2 (no spray foam) jefferyscott Building & Construction 17 01-04-2017 10:27 PM
Spray foam question Mlorek Insulation 1 03-28-2013 02:42 PM
Spray foam the interior of a exterior brick wall? Convict3 Insulation 13 08-21-2012 08:01 AM
Fireblock with spray foam application question toobhed Building & Construction 1 10-06-2011 10:56 AM
Hybrid wall insulation consisting of 2" rigid foam + 2x4 fiberglass batts? TitaniumVT Building & Construction 15 09-14-2010 03:50 AM
