Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 12-09-2011, 09:23 PM   #1
Laying batt FG insulation over attic floor
Small (900sf) house in Tennessee has no insulation under plywood flooring over joists. Started laying batt FB (w/ vapor barrier) insulation between joists behind knee walls. Don't want to pull up plywood flooring.
Thinking of just laying batt FB insulation directly over plywood flooring.
Question: Should I use a vapor barrier directly over plywood floor or just use insulation w/o vapor barrier?
rlandry is offline   Reply With Quote
Old 12-10-2011, 10:44 AM   #2
Exterior Construction
Windows on Wash's Avatar
Is the floor you are describing over a crawlspace? I think you have some of your terminology mixed up.
Can you post up a picture?
Old 12-10-2011, 10:53 AM   #3
Joist are under the house and rafters are what holds up the ceiling, is that what you ment to say?
Old 12-10-2011, 11:12 AM   #4
Sorry for sloppy terminology. I'm inquiring about an attic space. House is wood frame with gable roof. Wood rafters over attic. Plywood flooring in attic over 2x6 wood ceiling joists.
Attic is not being used for storage, so covering floor with batt or loose insulation is an option we're looking at.
Question is if we should lay down a vapor barrier over existing plywood flooring if no insulation/vapor barrier is between ceiling joists.
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 10:07 PM
New Floor Joists for 3rd floor attic remodel appleman11 Building & Construction 6 11-30-2011 03:43 PM
Is dark gray attic insulation ok? Is it worth replacing with batt insulation? entropyjx Insulation 7 11-23-2011 01:30 AM
Laying attic floor: what should I do about exposed wiring? scool Electrical 6 11-11-2010 12:23 PM
Split level walls and floor joists - how are they constructed? jrbutterfly Building & Construction 2 06-09-2009 01:11 PM
