Kitchen Remodel Surprise - Insulation - DIY Chatroom Home Improvement Forum
Old 07-23-2013, 02:48 PM   #1
I ‘m working on a house (built in ’96) that was sheathed with sheets of ¾ inch 4' x 8' plywood and sheets of Polyisocyanurate; that is some of the framing is covered with plywood and other portions with Polyisocyanurate. Then the whole structure was wrapped with Tyvek. The structure’s interior stud bays are filled with Kraft faced R19 fiberglass. The Kraft paper (facing the exterior) has turned black and the sole plates all show signs having been wet, no mold is visible. The interior side of the plywood sheathing shows signs of weathering. All of this was discovered while gutting the kitchen for a remodel. Since we have the drywall removed anyway what measures would you suggest on sealing and insulating this area? Thank you in advance for any information you can offer.
ToolMonger is offline   Reply With Quote
Old 07-23-2013, 04:05 PM   #2
Rewards Points: 13,750
Got a picture of the outside in this area?
Is there Storm and Ice Shield on your roof under the shingles up at least 4'.
Is there a vent through the roof n that are that may have a leaking seal?
Window on that wall?
Shingles left to short on the edge of the roof? They need to be hanging over at least 1/2"
Old 07-23-2013, 05:03 PM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 404
The facing on the insulation should go to the inside of the house, not the outside, unless there is something new I don't know about.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 07-24-2013, 01:03 PM   #4
Hey big Jim,
Thanks for responding. The facing is towards warm side or interior of the room. The portion that has turned black is where the fiberglass is glued to the paper. It looks like oil soaking through a brown paper bag. Whatever this stuff is it only appears on the insulation that was used on the exterior walls.
Old 07-24-2013, 01:22 PM   #5
Ole Wood Worker
BigJim's Avatar
Rewards Points: 404
Originally Posted by ToolMonger View Post
Hey big Jim,
Sorry, I misunderstood. I have seen that several times when the heat melts the adhesive, I don't think it will affect the efficiency of the insulation though.
Jim
Old 07-24-2013, 01:24 PM   #6
Hey joecaption,
Thanks for your reply. I'm not sure if there is a barrier in place. There is a vent for the kitchen sink on the north wall and both walls have windows. I'll climb up tonight a take a closer look.
Bear in mind that the kitchen is sandwiched between the main house and the garage. There are two exterior walls a north and a south, both have this issue. The south wall is setback 5 or 6 feet and the roof serves as the porch roof as well. Would a moisture barrier extend 4' up the roof of the south wall? If there isn't a leak how would go about air sealing the area and insulating it?
P.S. I will post some pictures
Old 07-26-2013, 10:43 PM   #7
Registered User
Rewards Points: 5,516
The black side should be the asphalt adhesive between the fiber/paper, this is made that way. The paper is your code required vapor retarder, if foamboard is not thick enough per your location; (cities below map) http://publicecodes.cyberregs.com/ic..._11_par002.htm
Prevent condensation; http://www.buildingscience.com/docum...r-requirements
Gary
Tags
insulation
How to remodel Kitchen johnsorious Remodeling 13 07-01-2013 04:29 PM
1970's single wide kitchen remodel Trin Building & Construction 1 05-08-2013 11:12 PM
kitchen remodel... color question(s) Rkn Interior Decorating 11 02-01-2013 10:58 AM
Kitchen remodel and venting joeh Plumbing 5 12-17-2011 06:38 PM
Kitchen remodel; ductwork pinkertonpv HVAC 3 02-18-2009 03:03 PM
