Kitchen Range Hood Pipe/duct Insulation And So On - Insulation - DIY Chatroom Home Improvement Forum
Old 09-23-2012, 02:07 AM   #1
Rewards Points: 200
Question
Kitchen range hood pipe/duct insulation and so on
Dear all, thanks again for reading my question.
We have a old kitchen hood pipe/duct which looks like this:
Quick questions:
1. Does that pipe/duct look like asbestos? If so is there any health concern about this?
2. If there is a health concern, what's the best way to fix this? If there is no health concern, how can we make it look nicer? I mean can we use aluminum foil to just wrap it up and then tape it?? Thoughts or comments?
Thanks again!
ohman is offline   Reply With Quote
Old 09-23-2012, 01:59 PM   #2
Rewards Points: 52
No expert but unless you tamper and release particles you should be ok. But if it is, technically should be dealt with by expert. Your pic is to blurry to get a good idea as to what it really is,could be mastic?
Can you post better picture?
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 10-09-2012, 02:19 PM   #3
Rewards Points: 43
I clicked on the pic and I can see a lot more detail in the larger version. Dont know what it is, but I can see it well!
Al
AlleyG is offline   Reply With Quote
Old 10-09-2012, 05:19 PM   #4
Rewards Points: 200
Yes that small picture was meant to be a thumbnail and you can click on the picture to see a larger picture. Just a quick FYI.
AlleyG thank you for point this out...
We talked to a handyman and he suggest to put a wooden board to block it (sort of creating a small compartment, instead of wrapping the duct with foil paper (or whatever materials that people use to wrap water heater ducts)... thoughts or comments about this approach?? thanks!
Old 10-13-2012, 12:59 AM   #5
Rewards Points: 200
OK the contractor friend of mine helped me to put a new duct in, here is a "AFTER" photo, hope this can help someone who has similar problems:
Fiberglass Insulation: How Do I Cover the Attic? chueh Building & Construction 3 11-08-2010 03:33 PM
New Unfaced Insulation Off gassing something common sense Building & Construction 3 10-07-2010 04:46 PM
Insulation in remodeled kitchen DanBress Building & Construction 1 01-03-2008 05:53 PM
Insulation under kitchen addition rubicon789 Carpentry 11 01-26-2007 04:24 PM
