Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 07-17-2012, 04:21 PM   #1
Just wondering about adding Insulation to a flat roof home?
My home is a flat roof and I believe it's 2x8 construction. I have an air gap of about 6 inches. The roofing is EPDM with some foam under it. The eave vent is about a 1 inch gap along the length of the roof.
My question is could I add any more insulation up there and not hurt the venting? It's been something I've wondered about but it way low on my list.
rodm1 is offline   Reply With Quote
Old 07-17-2012, 07:10 PM   #2
What is your climate like?
ionized is offline   Reply With Quote
Old 07-18-2012, 12:53 AM   #3
is the foam on the outside or inside of the roof sheathing?
Old 07-18-2012, 10:55 AM   #4
Exterior Construction
Windows on Wash's Avatar
Need more details.
Old 07-18-2012, 05:58 PM   #5
I'm in Michigan temps run from 20° to about 90° some times lower and higher but that is generally what you can expect.
The foam is over top of the old tar roof (Sheathing, Tar, Foam, last EPDM).
Anything else you need to now?
Thanks,
Rod
Old 07-18-2012, 07:11 PM   #6
So the venting is under the old sheathing at the original level then?
If that's the case, you are limited by insulation depth because you don't want to block off that venting. You can blow in more insulation in that interstitial space but don't block the vents.
Old 07-19-2012, 05:36 AM   #7
Correct, How close could I get to the sheathing? I believe I have about 7 inches of air space.
Old 07-19-2012, 08:04 AM   #8
Within an inch and the CC SPF has to be done in lifts.
I think we need some pictures of the attic because (no offense) the message is a bit jumbled.
Old 07-19-2012, 05:31 PM   #9
I'm afraid photo's won't be helpful there isn't anything to really see (no way to see the construction). If I add insulation it probable would be blown in insulation.
Old 07-21-2012, 01:50 AM   #10
Moderator
http://www.buildingscience.com/docum...+in+flat+attic
Gary
Clothes taking longer to dry?
Best way to replace/insulate a flat tar-gravel roof Hexar Roofing 19 10-08-2010 01:17 AM
Flat Roof and Blown Insulation... inlikeflint Building & Construction 4 01-26-2010 01:42 PM
what type of flat roof in coast home? starrider Roofing 7 02-19-2009 10:48 PM
Flat Roof Construction- insulation EricC Roofing 15 12-02-2007 09:49 PM
Need Help on the Flat Roof and more... MelindaA Roofing 12 12-21-2005 11:12 PM
