Isulating A Cinder Block House? - Insulation - DIY Chatroom Home Improvement Forum
Old 08-27-2011, 08:48 PM   #1
isulating a cinder block house?
We want to insulate a house, built in 1965, that is cinder block walls, some sort of stucco on the outside, with furring strips and pine paneling on the inside. What would be the simplest, cheapest way to insulate this? Do not know if there is a vapor barrier or house wrap. We live in an area that can go 20 below zero! It was used in the warmer months only. The ceilings and roof would need insulating too.
thanks for your help!!
gam62 is offline   Reply With Quote
Old 08-28-2011, 03:26 PM   #2
Registered User
Rewards Points: 4,888
I'd use an insulation that could get wet due to the stucco wicking water---- rigid closed-cell foam board. The roof is; vaulted, flat, pitched, gabled, hip, low-pitched, metal, etc.....
Gary
Installing a new windows in cinder block foundation monsterbash Building & Construction 1 04-13-2009 08:48 AM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 03:28 PM
Cinder block wall hangings shnfldr Remodeling 2 06-07-2008 09:26 AM
Leak in the cinder block foundation. 68MHJCs Building & Construction 7 01-25-2008 10:37 AM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
