Interior Wall Insulation Batting - Insulation - DIY Chatroom Home Improvement Forum
Old 06-22-2013, 02:25 PM   #1
interior wall insulation batting
In the interest of full disclosure, I am a newbie to the site, so please forgive any faux pas in my posting.
Issue, I am acting as "owner/builder" on a new home in Angel Fire, New Mexico. As such, I am attempting to do the relatively fool-proof stuff to save money!
Most of my interior walls are 2" x 6" studs that will, hopefully, better ensure the lessening of sound transference between rooms. Ergo, my question has to do with "which size batting" (proposed Pink Panther roll) to use.
Can I (or should I) use 3.5" (R13) in these walls and install two layers, or just one layer of 6.25" (R19). I can purchase two-times the equivalent 3.5" coverage ($9.98/roll - $0.25 sq.ft.) for less than the cost of one-times the equivalent 6.25" coverage ($22.95/roll - $0.47 sq.ft.).
If I do the "2-layer" approach, will the necessary 3/4" additional compression factor destroy any gains made over using the standard 6.25" batting designed for a 2" x 6" stud wall? Sorry for the long message, and any confusion I may have created in forming the question(s).
goodyt is offline   Reply With Quote
Old 06-23-2013, 09:23 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,784
The slight over compression of the R13 batt does not destroy its insulation value and actually helps it a tiny bit by making it a bit more high density.
You did mention interior walls so the R-Value question is moot anyway.
How much sound proofing are you wanting because insulation alone may not do the trick.
Old 06-23-2013, 11:10 AM   #3
Windows,
Thank you for your response. Of course you are correct regarding the R factor issue. It was one of those times where I was thinking along one line and writing something entirely different. I included the R factors only to further delineate which density I proposed.
My concern is about sound deadening. The house in question is a chalet-type structure in Angel Fire, NM, and, as such, will be subject to multiple inhabitants at various times.
The good news, since I am the Papa Bear in the group, of course I will be sleeping on the 3rd level (master bedroom). However, the bad news, I am a poor sleeper and routinely find myself awake (and up) in the wee hours of the night! Just trying to be considerate of the guest bedrooms on the 2nd level.
Thanks again for your response. Have a great day!
Old 06-23-2013, 02:48 PM   #4
If you are worried about deadening the noise transmission from the upper floors, sound isolation will be via uncoupling the upper floor framing.
This done via a number of different ways and if you search around this board, there are some pretty well hashed out arguments and options when it comes to sound attenuation.
Old 06-23-2013, 06:33 PM   #5
Many thanks. I will start searching. Have a great day.
Existing blow in insulation vs new insulation - Keep or redo? Jaxx Insulation 9 01-17-2014 09:26 AM
Insulation question for vaulted home Talgonadia Insulation 3 08-22-2012 07:06 AM
?'s about foil-faced "bubble wrap" insulation badger73 Insulation 5 06-25-2012 06:09 AM
Several Insulation Quotes, Big Decisions to make knotquiteawake Insulation 2 05-04-2012 12:16 PM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 09:14 PM
