Insultation Of Duct Work - Insulation - DIY Chatroom Home Improvement Forum
Old 05-30-2012, 07:20 PM   #1
Rewards Points: 198
insultation of duct work
so the previous own decided to run the duct work underneath the sun room ,which is also exposed to the elements. The duct is a cold/hot air feed for the room directly above and the 2nd floor. Due to the small size of the A/C unit. my house really does have a cooling problem. I'm in the process of identifying all the leaks and try my best to seal up the place best i can.
anyhow, on to the duct work. you can see that there is some insulation material in the area but i can def feel a cold draft if i stick my hand in the space. Question is how to best insulate this space? canned foam?? or do i need to build something to cover it completely.
http://imgur.com/x7MUd
vote4Pedro is offline   Reply With Quote
Old 05-30-2012, 07:28 PM   #2
Rewards Points: 6,652
Your best bet is to tear all of the ceiling material down and open it up, so that you can get up there. It also, would give you a chance to fix any problems at the house side, re-route the catv wires, and then attack the duct work, then insulation. If you spray foam, get a few bids and ask if you can also get referrals for current jobs if any, or prev. jobs that you can talk to those people.
The Following User Says Thank You to gregzoll For This Useful Post:
Windows on Wash (05-30-2012)
Old 05-30-2012, 07:53 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,244
Rip it all down and do it right.
Old 05-31-2012, 09:09 AM   #4
Rewards Points: 198
is what they've done really wrong? i hate to turn a small job in to a major job with minimal gains.
Old 05-31-2012, 01:21 PM   #5
Do some spot demo and post up some pictures. If that is how they left it, odds on favorite that other stuff is wrong and it is impossible to tell for the picture that you posted.
Resi breakers, testing of Yoyizit Electrical 10 07-14-2010 07:49 PM
Backflow device testing - possible scam? ScottR Plumbing 9 06-14-2009 10:55 AM
Testing circuit with GFCI protection Hodag Electrical 4 09-15-2008 10:43 PM
Testing DC Rze Electrical 3 09-15-2007 09:02 AM
Testing Formss Deano710Sparkey Electrical 2 04-13-2007 01:33 AM
