Insullation In 2nd Floor Ceiling - Yes Or No? - Insulation - DIY Chatroom Home Improvement Forum
Old 10-02-2013, 03:59 PM   #1
Insullation in 2nd floor ceiling - yes or no?
Hi all,
I'm about to re-insullate my whole house (all walls and ceilings /studs and joists are exposed now).
My attic roof is insullated (2x6 rafters, not sure what type of insullation is in there, its not fiberglass, its grey and has a brittle paper holding it all up against the rafters and roof sheathing).
The second floor ceiling was not insullated previously (house was built in 1925). Should I go ahead and insulate the second floor ceiling with R19? I have 2x6 joists.
The attic is not a living space, its just for storage.
I think extra insullation would be great, but not sure about vapor barriers. If I have insullation already in the attic roof, do I want insullation and then a vapor barrier before I sheetrock the 2nd floor ceiling.
I don't see any kind of vapor barrier on the attic insullation aside from the paper facing.
Just don't want to go ahead and add insullation and vapor barrier and then end up with some kind of problem.
The roof looks to be a ridge ventilated type (roof was done 2 years ago, prior to me owning it). I'm assuming this because I do not see any vents near the eaves (i removed a little of the old insullation to take a peek).
I live in Northern NJ, so I do get a winter.
twincharged rx7 is offline   Reply With Quote
Old 10-03-2013, 11:39 PM   #2
Registered User
Rewards Points: 5,516
R-38, minimum code; http://energycode.pnl.gov/EnergyCode...e=New%20Jersey
No insulation between living space floors. If you cannot meet code minimum ventilation rates, go unvented attic; http://www.buildingscience.com/docum...on?full_view=1
Zone 5; http://www.buildingscience.com/docum...rchterm=attic+
Imperative to air seal the attic first; http://www.buildingscience.com/docum...sealing-guide/
Gary
Old 10-04-2013, 02:25 PM   #3
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Expounding on Gary's comments, the ideal situation would be to remove the insulation from the underside of the roof deck, and the air seal and insulate the attic floor/2nd floor ceiling to code (I prefer r50). Currently you are essentially bringing your attic into the building envelope and wasting energy. This would correct that, although it would be at the expense of your storage area... Gotta pick what is more valuable to you.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 10-04-2013, 04:11 PM   #4
Rewards Points: 2,638
But this would also require adding soffit vents, so the attic is properly ventilated, right?
SPS-1 is offline   Reply With Quote
Old 10-04-2013, 05:52 PM   #5
Thanks for all the info. Based on that website, I have an invented roof, which is ok for my climate as long as the insulation and air barriers are correct
Also, I can't need code if I rip out the insulation under the roof deck, as I only have 2x6 joists on the second floor and the attic has floor boards, so I can't just throw down a ton of insulation.
Ill be going with insulation in the 2x6 joists and a vapor barrier. Ill also keep the existing insulation under the roof deck.
Unless of course someone has seen this fail and result in extra moisture.
On the website linked to they actually say its better for my air handling equipment (more efficient) if the attic is enveloped into the house (insulation under the roof deck)
Old 10-05-2013, 02:03 PM   #6
Registered User
Either vent the attic or not. When not, you need foam (spray) or foam board next to the sheathing as that link brought out. See the map and read the whole article, her; http://www.buildingscience.com/docum...n-roof-venting
http://www.buildingscience.com/docum...ation-packages
Gary
Old 10-05-2013, 03:43 PM   #7
Home Performance
HomeSealed's Avatar
Rewards Points: 712
That i sfine if that is route that you want to go. Like I said, pick where you want the envelope to be, it would be incorrect to try and do both. Th efloor boards would get ripped up, or dense packed and then loose fill blown over if you wanted to go that route, otherwise if you prefer to condition the attic then follow Gary's links.
www.HomeSealed.com
Smashing down blow in insullation BackYardBuilt Insulation 20 01-18-2012 07:02 AM
Insullation between knee-walls 42nat1 Insulation 6 11-22-2011 11:06 PM
Dishwasher Insullation CJDW General DIY Discussions 3 03-29-2011 06:39 PM
Insullation in Attic???????????? S4man Building & Construction 7 02-12-2008 07:36 PM
how do I attach the insullation between studs? yummy mummy Remodeling 11 11-02-2006 09:31 PM
