Insulation For Walls In South Florida - Insulation - DIY Chatroom Home Improvement Forum
Old 08-04-2012, 01:54 PM   #1
Insulation for walls in South Florida
I live in South Florida . In the middle of installing a tankless hot water heater I found wet dry wall and pulled it all out . My question is since I live in South Florida do I need insulation in the walls . I have insulation in the attic . But would I need it for the walls and if so what kind would I need .
Amberlily is offline   Reply With Quote
Old 08-04-2012, 04:09 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 850
Insulation works in all climates.
Unfaced fiberglass is probably your most readily available insulation and will work just fine.
Get the high density version.
Old 08-04-2012, 05:06 PM   #3
Rewards Points: 12,802
#1 Why was the insulation wet?
http://www.energystar.gov/index.cfm?...sulation_table
Unless your whole house is under ground then it should be insulated.
How else would you keep cold air in and hot air out in the summer.
Old 08-09-2012, 03:52 PM   #4
Rewards Points: 1,092
Amber: If you run air conditioning and have a vapor barrier on the inside of your walls (plastic sheathing, visqueen, poly) you may have wet insulation because the moist outside air has been condensing on the poly (poly is cold when you run the A/C). That is a huge problem sometimes, and it may be wise to investigate your whole house for wet insulation. If everywhere else is dry, then look for some kind of leak in the present area. If the whole house is wet, you've got some real work to do to pull the poly (if that is the problem; get expert help if the whole house is wet).
Existing blow in insulation vs new insulation - Keep or redo? Jaxx Insulation 9 01-17-2014 09:26 AM
Garage Insulation yamster Insulation 0 07-01-2011 02:30 PM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 09:14 PM
Has anyone used Green Fiber blown in insulation? pomelo Building & Construction 7 02-10-2010 08:17 AM
closed cell vs open cell foam insulation amonalisa Building & Construction 1 11-06-2008 10:39 PM
