I live in South Florida . In the middle of installing a tankless hot water heater I found wet dry wall and pulled it all out . My question is since I live in South Florida do I need insulation in the walls . I have insulation in the attic . But would I need it for the walls and if so what kind would I need .
Amber: If you run air conditioning and have a vapor barrier on the inside of your walls (plastic sheathing, visqueen, poly) you may have wet insulation because the moist outside air has been condensing on the poly (poly is cold when you run the A/C). That is a huge problem sometimes, and it may be wise to investigate your whole house for wet insulation. If everywhere else is dry, then look for some kind of leak in the present area. If the whole house is wet, you've got some real work to do to pull the poly (if that is the problem; get expert help if the whole house is wet).
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
