#1 |
Insulation in walls of 2nd floor
We are tearing down all the Sheetrock walls on the 2nd floor and will be running new electric. I'm not sure what is behind the walls insulatiion wise but whether we think it is okay or put new insulation between all the studs is that all to be done? I saw a pic of plastic nailed to the studs covering the insulation. Is this typical? Thanks
#2 |
Insulation in walls of 2nd floor |
#3 |
Moderator
Your location would help...
Gary
Clothes taking longer to dry?
Clean the dryer screen in HOT water if using fabric softener sheets. They leave a residue that impedes air-flow, costing you money. Clean the ducting in the last six months? 17,000 dryer fires annually! |
#4 |
Average Joe/ex-Navy IC3
Really do not understand why you need to gut the complete upstairs, unless you found out while pulling existing permits on the place, that a whole lot of corners were cut. BTW, if you replace electric in your place, you then have to bring it up to current codes, and that means AFCI for all areas specified by your AHJ & the NEC.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you? |
#5 |
#6 | |
Insulation in walls of 2nd floorQuote:
#7 |
That makes better sense. While have the walls open, pull Cat-6 or cat-5e for telephone and/or network wiring, coax also. Also make sure you seal any holes in the walls, to help airseal between attic spaces, and the floors below.
| The Following User Says Thank You to gregzoll For This Useful Post: | Mstrlucky74 (02-23-2013) |
#8 |
Moderator
Cavity insulation requires air sealing of the cavity; https://docs.google.com/viewer?a=v&q...M8l_EeA2F-qvvA
Caulk the plates/studs/sheathing joints also, or expect a 40% heat loss due to air infiltration/exfiltration, when the wind blows outside. Contact the fibrous insulation batt with the drywall or expect a 300% loss, fig. 2a,3a; https://docs.google.com/viewer?a=v&q..._NGatSVo3wzmAQ Tips; http://oikos.com/library/insulating_...lls/index.html http://www.advancedinsulationinc.com...Insulation.pdf Air-seal the sheathing, page 21; http://www.engr.psu.edu/phrc/trainin...ngbarriers.pdf Simply adding more insulation rather than air sealing won't help much, pp.40: http://www.buildingscience.com/docum...-climate-zones ADA the drywall: http://www.buildingscience.com/docum...wall-approach/ Many people don't understand that the air seal importance is equal to the insulation importance, or greater. Even local building codes are requiring it now- "between dis-similar materials- because they expand/contract differently; producing cracks/gaps for air in/out (with the air rides moisture); "N1102.4.1 Building thermal envelope. The building thermal envelope shall be durably sealed to limit infiltration. The sealing methods between dissimilar materials shall allow for differential expansion and contraction. The following shall be caulked, gasketed, weatherstripped or otherwise sealed with an air barrier material, suitable film or solid material." Now read the list; http://publicecodes.cyberregs.com/ic..._11_par035.htm When fiberglass is tested for it's R-value = a closed, six-sided box with NO air leaks is used.... add some wood studs (R-1.5 per inch thickness) for a thermal loss and "heat sinks"; http://www.coloradoenergy.org/procor...f/r-values.htm Let me know if you need another tip for a warmer room...it takes a little more work, though. Gary PS. vapor barrier/retarder; http://www.buildingscience.com/docum...commendations/
| Display Modes | |
| Crawlspace insulation, walls or floor | fullermatt | Insulation | 5 | 01-02-2013 09:27 PM |
| Insulate rim joist & basement walls- if exterior walls have no insulation? | cbrc5eric | Insulation | 5 | 02-01-2012 08:47 AM |
| Attic insulation over old attic floor | beffreyj3 | Insulation | 6 | 11-18-2011 08:21 AM |
| Insulation in basement floor joists and integrated garage | speedster1 | Building & Construction | 3 | 12-07-2010 06:44 PM |
| Rafter Vents and Insulation | nofx1981 | Roofing/Siding | 15 | 03-10-2010 09:14 PM |
