Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 11-09-2012, 10:18 AM   #1
sht
Question
Insulation UNDER mantle
Our gas log fireplace puts out so much heat that the bottom side of the mantle gets very hot. The previous owners had all wiring for the TV over the fireplace so the TV is mounted there and the wires are hidden under the mantle (it is not solid). I'm concerned about the heat on the wires. Can you suggest an insulation or other material that I could use to deflect the heat and keep the wiring under the mantle from getting hot.
sht is offline   Reply With Quote
Old 11-09-2012, 10:48 AM   #2
Exterior Construction
Windows on Wash's Avatar
Some sort of foil or radiant barrier would be best.
Old 11-09-2012, 11:10 AM   #3
sht
I used aluminum foil as a quick, temporary shield. I think I need something more substantial, and removable so I can get to the wires. My husband thinks it needs to be some type of insulation to keep the heat out.
Thanks for the suggestion.
Tags
insulation, mantle
Insulation question for vaulted home Talgonadia Insulation 3 08-22-2012 07:06 AM
?'s about foil-faced "bubble wrap" insulation badger73 Insulation 5 06-25-2012 06:09 AM
Several Insulation Quotes, Big Decisions to make knotquiteawake Insulation 2 05-04-2012 12:16 PM
Garage Insulation yamster Insulation 0 07-01-2011 02:30 PM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 09:14 PM
