Insulation Type Needed If Using RedGard Waterproofing? - Insulation - DIY Chatroom Home Improvement Forum
Old 09-26-2011, 07:01 PM   #1
Insulation type needed if using RedGard waterproofing?
Hello everyone! First off, I would like to say this forum is pretty cool! This is my first post, but have gleaned some good information from here already. So here is my sitution....
I am remodeling my bathroom and am trying to do it correct because whoever remodeled it years ago was an idiot I am no expert on building, but common sense apparently wasnt part of this persons genes.
So my question is this...I have an alcove that has two exterior walls where the tub will be going and I plan to use hardiebacker 1/2" for the entire wet area (including ceiling) and it will be tiled. I plan on using RedGard waterproofing membrane over the cbu, but not sure of what type of insulation to use behind the cbu for the exterior walls. Right now I have some new Certainteed R-15 in there with the paper facing on it, but I THINK the paper is also a vapor barrier, so I dont want to cause a situation with moisture build up between the cbu and insulation by having essentially a double vapor barrier. Should I remove the paper facing from the insulation or is it ok to keep it there when using Redgard?
bigphil is offline   Reply With Quote
Old 09-28-2011, 11:57 AM   #2
ccarlisle's Avatar
Well, the theory goes that a waterproofing membrane such as RedGard will, if installed properly, prevent any vapour from diffusing across the cbu and into the wall structure where, in cold months, it will condense to water. As such, the problem 'goes away' in that no vapour=no problem...and therefore no vapour retarder behind the cbu is needed. Insulation yes - but no vapour retarder; I subscribe to that theory so I'd say either remove the little bit of faced insulation you have, or remove the paper facing of it...
But since you're already there, why not upgrade to Roxul mineral wool, if buying a bag isn't too much for you to use? If so, then buy a small bag of pink fibreglass insulation and be done.
Not too sure where you're located but this should hold up pretty well anywhere...
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
The Following User Says Thank You to ccarlisle For This Useful Post:
Bud Cline (09-28-2011)
Old 09-28-2011, 12:43 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I would agree with the above but take it one step forward and suggest you use Denshield instead of Hardbacker. Denshield offers a protective coating and all that has to be addressed then is the seams and fastener penetrations. Denshield is also much much much easier to work with and the fasteners will be easy to "set-the-heads".
Old 09-29-2011, 01:13 PM   #4
Thank you both for the replies. I'm in Seattle btw. well...I already purchased the hardiebacker and my buddy had a bag of r15 yellow fiberglass batts (freebie) that fit perfect so thats what I used. I suppose I'll just keep the paper on the insulation then because I already have some cbu up there and its a pain to take it down. I'll be sure to apply the RedGard properly to be sure its 100% waterproof (i'll probably throw 3 layers on instead of two). thanks again!
Old 09-29-2011, 02:02 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Hardibacker will easily require a minimum of three applications.
Garage Insulation yamster Insulation 0 07-01-2011 02:30 PM
2x4 Exterior Wall Insulation stubits Building & Construction 4 03-19-2009 08:03 AM
Old home insulation woes nowwhatnapster Building & Construction 15 11-03-2008 12:59 AM
Type of insulation to install? sandyman720 Building & Construction 2 01-23-2008 11:31 PM
what type of insulation? aokss Building & Construction 2 06-25-2006 08:10 PM
