Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 07-16-2012, 01:57 AM   #16
Insulation Thickness
Thanks both for those links. Come to think of it, I think I even read the second one, if not the first. I esp like this, from the conclusions: "Instead of a vapour barrier, these results suggest that an air barrier might be all that is required to
control condensation in the below-grade portion of the basement wall." That ought to be enough to convince an inspector that poly is not the best in this situation.
Several Insulation Quotes, Big Decisions to make knotquiteawake Insulation 2 05-04-2012 12:16 PM
Existing blow in insulation vs new insulation - Keep or redo? Jaxx Insulation 8 02-24-2012 10:09 AM
Garage Insulation yamster Insulation 0 07-01-2011 02:30 PM
rigid insulation thickness for a condo/townhouse goldberg245 Insulation 1 03-22-2011 10:00 PM
Rafter Vents and Insulation nofx1981 Roofing 15 03-10-2010 09:14 PM
