Insulation / Roofing Problem - Insulation - DIY Chatroom Home Improvement Forum
Old 03-15-2012, 03:27 PM   #1
Insulation / roofing problem
I recently was part of a whole house renovation and the homeowner had closed cell foam insulation done in the entire house. The roofing used on this project is a basic GAF Timberline series with normal underlayment. About a year has gone by and the roof in three different places is starting to bubble, all on the same slope and all apx. the same distance from the ridge. I have never seen this condition before and there are no nails causing this. Has anyone ever heard of or seen this condtion. I read somewhere online that sometimes closed cell if done to thickly can actually retain heat for long periods of time and possibly cause this???? Any help would be appreciated.
fceneil is offline   Reply With Quote
Old 03-16-2012, 09:28 PM   #2
Registered User
Rewards Points: 526
Solar driven moisture is what it sounds like, and it could go back to normal- over time/seasons, Fig.13, 14: http://www.buildingscience.com/docum...on?full_view=1
Foam against OSB is usually risky as it needs an air gap on one side (at least) to dry out because the product is hygroscopic; http://www.buildingscience.com/docum...d%20in%20walls
The impermeable roofing shingles stop any moisture in the OSB from drying on one side, foam stops it on the other- “Practical Recommendations”, pp.5, second and third bullet: http://www.earthane.com/ctu32e.pdf
Or it could be edge swelling, if it is that, may be irreversible: http://www.ewpa.com/Archive/2006/aug/Paper_266.pdf
And it could be none of the above---- did you check in the attic for a moisture source?
Gary
Help with complicated insulation project in attic OhmZoned Insulation 12 11-19-2011 08:49 AM
DIY sunroom stuck with roofing problem rbyham Roofing/Siding 12 08-09-2011 02:17 PM
Metal Roofing and Insulation bforrest13 Roofing/Siding 6 03-12-2011 08:06 AM
roofing and insulation question everyman Building & Construction 23 06-12-2009 07:32 PM
steel building insulation problem rjf Building & Construction 17 02-09-2007 06:24 AM
