Insulation Removal - Insulation - DIY Chatroom Home Improvement Forum
Old 02-03-2014, 11:13 AM   #1
insulation removal
Does anyone know of a company that will remove the blown in insolation from attic? If you ask why , it is that every time I go up to do something it becomes a dust bowl. I would rather roll back insolation then deal with this type of insolation.
dusty247 is offline   Reply With Quote
Old 02-03-2014, 11:41 AM   #2
Rewards Points: 1,294
Where do you live?????????????????
danpik is online now   Reply With Quote
Old 02-03-2014, 11:45 AM   #3
I am in the outskirts of Detroit MI
Old 02-03-2014, 01:27 PM   #4
Well, my guy can't do it for you then. He is a blow-in insulation contractor and has the ability to vacuum out insulation from attics.
Old 02-03-2014, 01:37 PM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 878
How many times are you having to get into your attic?
Most insulation companies will have removal tools as well.
Old 02-03-2014, 09:44 PM   #6
Professional
TotalHomeworx's Avatar
Yes, most companies that blow it in will suck it out. What are you doing up there all the time that you can't just wear a mask?
TotalHomeworx is offline   Reply With Quote
The Following User Says Thank You to TotalHomeworx For This Useful Post:
Windows on Wash (02-04-2014)
Existing blow in insulation vs new insulation - Keep or redo? Jaxx Insulation 9 01-17-2014 09:26 AM
Insulating your attic Bob Mariani How To Guides 5 07-07-2013 09:49 PM
Insulation maitenance after remodel k2000lbs Insulation 10 02-19-2012 11:04 AM
Basement Ext Wall - Will Rigid Insulation allow my wall to dry inward? COLORADOMTNMAN Insulation 10 01-15-2012 11:09 PM
Do it yourself insulation removal spowell612@knology.net Building & Construction 2 12-30-2008 07:43 AM
